查看: 1746|回复: 4
如何得到选择集中块的名称
发表于 2004-5-5 23:48:00 | 显示全部楼层 |阅读模式
用下面的办法,不能得到对象的名字,特别是块的: For Each entry In ThisDrawing.ActiveSelectionSet
entName = entry.ObjectName
lObjectID = entry.ObjectID
s = "Name:" & entName & ", ID:" & lObjectID & vbCrLf
entry.Highlight (True)
ThisDrawing.Application.Update
MsgBox s
entry.Highlight (False)
Next
那位高手指点一下
发表于 2004-5-6 07:18:00 | 显示全部楼层
  1. Sub gs()
  2.        Dim entry As AcadEntity
  3.        Dim entname As String
  4.        Dim lObjectID As Long
  5.        Dim s As String
  6.        Dim BlkName As String
  7.        For Each entry In ThisDrawing.ActiveSelectionSet
  8.                entname = entry.ObjectName
  9.                lObjectID = entry.ObjectID
  10.                BlkName = ""
  11.                [b]If entname = "AcDbBlockReference" Then BlkName = " , BlockName:" & entry.Name
  12.                s = "Name:" & entname & ", ID:" & lObjectID & BlkName & vbCrLf[/b]
  13.                entry.Highlight (True)
  14.                ThisDrawing.Application.Update
  15.                MsgBox s
  16.                entry.Highlight (False)
  17.        Next
  18. End Sub
发表于 2004-5-6 07:46:00 | 显示全部楼层
  1. entname = "AcDbBlockReference"
复制代码
这里是否可以改成Ucase(entname) = "ACDBBLOCKREFERENCE"大小写转换起来太累,也容易出错
发表于 2004-5-6 08:08:00 | 显示全部楼层
高手呀就是高手!佩服!!!
 楼主| 发表于 2004-5-6 14:45:00 | 显示全部楼层
多谢大家,真是职业人呀,佩服,这么早就回了
GMT+8, 2025-5-1 06:30 , Processed in 0.151615 second(s), 23 queries , Gzip On.
