查看: 4346|回复: 0
csharparx ....
发表于 2004-5-8 21:27:00 | 显示全部楼层 |阅读模式
using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using System.Reflection;
using System.IO;
using System.Collections;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using System.Diagnostics;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Colors;
using DBTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager; namespace setenv
public class entites
private Database db;
public entites()
db= Application.DocumentManager.MdiActiveDocument.Database;
//创建多义线
public bool createPolyline(Point3dCollection ptArr,string lyrname)
DBTransMan tm= db.TransactionManager;
Transaction myT = tm.StartTransaction(); BlockTable bt=(BlockTable)tm.GetObject(db.BlockTableId, OpenMode.ForRead, false);
BlockTableRecord btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite,false);
try
DoubleCollection blgs=new DoubleCollection();
for(int i=1;i<=ptArr.Count;i++)
blgs.Add(0.0);
Polyline2d pline=new Polyline2d(Poly2dType.SimplePoly,ptArr,0.0,false,0.0,0.0,blgs);
pline.Layer=lyrname;
btr.AppendEntity(pline);
tm.AddNewlyCreatedDBObject(pline, true);
myT.Commit();
finally
bt.Close();
btr.Close();
myT.Dispose();
return true;
//创建新层
public bool createNewLayer(string lyrname,string ltname,short lyrcolor)
ObjectId objId=db.LayerTableId ;
LayerTable lyrTb=(LayerTable)objId.Open(OpenMode.ForWrite);
try
if (!lyrTb.Has(lyrname))
LayerTableRecord lyrTbr=new LayerTableRecord();
lyrTbr.Name=lyrname;
lyrTbr.IsFrozen=false;
lyrTbr.IsOff=false;
lyrTbr.ViewportVisibilityDefault =true;
lyrTbr.IsLocked=false;
Color color1=new Color() ;
color1.ColorIndex =lyrcolor;
lyrTbr.Color=color1;
lyrTbr.LinetypeObjectId =getLineTypeId(ltname);
lyrTb.Add(lyrTbr);
lyrTbr.Close();
finally
lyrTb.Close();
return true;
//获取ltname 线型ID
private ObjectId getLineTypeId(string ltname)
ObjectId objId=db.LinetypeTableId ;
ObjectId id1=new ObjectId();
LinetypeTable ltTb=(LinetypeTable)objId.Open(OpenMode.ForRead);
if(!ltTb.Has(ltname))
id1= ltTb["CONTINUOUS"];
else
id1= ltTb[ltname];
ltTb.Close();
return id1;
protected void Dispose( )
} } } 调用 [CommandMethod("mycmd1")]
public static void mycmd1()
Point3dCollection ptArr=new Point3dCollection();
Point3d pt1=new Point3d(0,0,0);
Point3d pt2=new Point3d(1,1,0);
Point3d pt3=new Point3d(2,2,0);
ptArr.Add(pt1);
ptArr.Add(pt2);
ptArr.Add(pt3);
string lyrname="0";
entites ets=new entites();
ets.createPolyline(ptArr,lyrname);
ets.createNewLayer("1","HIDDEN",2);
参与人数 1威望 +1 金钱 +3 贡献 +1 激情 +1 收起 理由
zfbj + 1 + 3 + 1 + 1 【好评】好程序适合初学者的程序
GMT+8, 2025-11-26 14:19 , Processed in 0.196825 second(s), 24 queries , Gzip On.
