查看: 1666|回复: 3
请教这段代码中的问题
发表于 2004-5-10 17:24:00 | 显示全部楼层 |阅读模式
Dim d As Double
Dim l As Double
Dim lineent1 As AcadLine
Dim lineent2 As AcadLine
Dim l1 As AcadLine
Dim l2 As AcadLine
For i = 0 To vliness.Count - 2
For Each lineent1 In allentss
If (lineent1.StartPoint(0) = intPointarr(i) Or lineent1.EndPoint(0) = intPointarr(i)) And lineent1.StartPoint(1) = lineent1.EndPoint(1) And lineent1.StartPoint(1) < Centeryy Then
Set l1 = lineent1
End If
Next 'type mismatch ????
For Each lineent2 In allentss
If (lineent2.StartPoint(0) = intPointarr(i) Or lineent2.EndPoint(0) = intPointarr(i)) And lineent2.StartPoint(1) = lineent2.EndPoint(1) And lineent2.StartPoint(1) > Centeryy Then
Set l2 = lineent2
End If
Next
d = Sqr((l1.StartPoint(0) - l1.EndPoint(0)) ^ 2 + (l1.StartPoint(1) - l1.EndPoint(1)) ^ 2)
l = Abs((l1.StartPoint(1) - Centeryy) * 2)
Next
发表于 2004-5-10 18:38:00 | 显示全部楼层
把问题提出来啊,不然还得麻烦别人从头看到尾,不好意思吧?
 楼主| 发表于 2004-5-10 20:20:00 | 显示全部楼层
红色部分啊 运行到这里提示 type mismatch
发表于 2004-5-10 23:13:00 | 显示全部楼层
allentss是什么东东?
GMT+8, 2025-5-25 22:30 , Processed in 0.163763 second(s), 23 queries , Gzip On.
