查看: 9213|回复: 16
一个结合Lisp的拖动例子
发表于 2004-5-14 11:36:00 | 显示全部楼层 |阅读模式
Lisp函数:,先导入一下
  1. (defun Drag( pBlock / ppnt ed ped)
  2. (defun GetPoint( / a pnt )
  3.    (setq a (grread t))
  4.    (setq pnt (list 0 0 1))
  5.    (if (= 3 (car a)) (setq pnt (list 0 0 -1)))
  6.    (if (= 5 (car a)) (setq pnt (cadr a)))
  7.    pnt
  8.   )
  9.    (while (not (= (caddr (setq ppnt (GetPoint)))   -1))
  10.    (setq ed (entget (handent pBlock)))
  11.    (setq ped (list 10 (car ppnt) (cadr ppnt) (caddr ppnt)))
  12.    (setq ed (subst ped (assoc 10 ed) ed))
  13.    (entmod ed)
  14.    )
  15. )
测试(由于拖动在Lisp中做好了,不需频繁调用Vlax类,应该不会使AutoCAD崩溃):
  1. Sub Test()
  2.        Dim obj As VLAX
  3.        Dim c(2) As Double
  4.        Dim pObj As AcadBlockReference
  5.        Set obj = New VLAX
  6.        Set pObj = ThisDrawing.ModelSpace.InsertBlock(c, "123", 1, 1, 1, 0)
  7.        a = "(drag " & Chr(34) & pObj.Handle & Chr(34) & ")"
  8.        obj.EvalLispExpression (a)
  9.        Set obj = Nothing
  10. End Sub
参与人数 1威望 +1 金钱 +10 贡献 +5 激情 +5 收起 理由
mccad + 1 + 10 + 5 + 5 【精华】好程序
发表于 2004-5-15 14:05:00 | 显示全部楼层
看不懂啊~~~
是不是插入图块时能显示图块?
 楼主| 发表于 2004-5-15 19:33:00 | 显示全部楼层
差不多是这个意思
思路是在VBA里插入一个块
再通过Vlax类调用Lisp函数Drag做拖动
模拟Move命令的操作
(当然没有Move做的好,因为Lisp毕竟不是我的强项,只懂点皮毛)
 楼主| 发表于 2004-5-16 14:40:00 | 显示全部楼层
改良版(不需导入Lisp函数)
  1. Public Sub BlockInsert(Name As String)
  2.        Dim pLisp As String
  3.        Dim obj As VLAX
  4.        Dim pnt(2) As Double
  6.        Set pObj = ThisDrawing.ModelSpace.InsertBlock(pnt, Name, 1, 1, 1, 0)
  7.        obj.EvalLispExpression "(setq ed (entget (handent " & ToStr(pObj.Handle) & ")))"
  8.        pLisp = "(while (not (= (caddr " & _
  9.                        "(setq pTime (grread t) " & _
  10.                                    "pSt (car pTime) " & _
  11.                                    "pnt (cond ((= pSt 3) (List 0 0 -1)) ((= pSt 5) (cadr pTime)) (t (List 0 0 1)))))   -1)) " & _
  12.                        "(setq ed (subst (cons 10 pnt) (assoc 10 ed) ed)) " & _
  13.                        "(entmod ed) " & _
  14.                        ") "
  15.        obj.EvalLispExpression pLisp
  16.        Set obj = Nothing
  17. End Sub
  1. Public function ToStr(ByVal str) As String
  2.        ToStr = Chr(34) & str & Chr(34)
  3. End Function
  1. Sub test()
  2.        BlockInsert "123"
  3. End Sub
发表于 2004-5-23 16:10:00 | 显示全部楼层
2002怎么没有VLAX类?
发表于 2004-5-23 17:07:00 | 显示全部楼层
vlax 如何引用?
"Dim obj As VLAX"
 楼主| 发表于 2004-5-23 17:10:00 | 显示全部楼层
Dim obj As VLAX
Set obj = New VLAX
发表于 2004-5-23 18:09:00 | 显示全部楼层
执行到"Dim obj As VLAX"是显示用户类型未定义。也就是说你的代码不能直接运行(cad2000)。请指教,谢谢。
 楼主| 发表于 2004-5-23 18:10:00 | 显示全部楼层
VLAX类未导入
发表于 2004-5-23 18:14:00 | 显示全部楼层
究竟怎么导入?我对vlax一窍不通。
要想运行你的代码,还要设置些什么?谢谢
GMT+8, 2025-5-24 14:00 , Processed in 0.196971 second(s), 25 queries , Gzip On.
