查看: 2869|回复: 5
关于AcDbHatch的问题?
发表于 2004-5-14 18:06:00 | 显示全部楼层 |阅读模式
我是一个初学者,请各位帮我看一下,下面是画一个园,然后填充,程序编译通过,但运行时没有填充出来。 void test()
ads_point pt1;
if(ads_getpoint(NULL,"\n请输入插入点:",pt1)!=RTNORM) return;
AcGePoint3d basePoint(pt1[0],pt1[1],pt1[2]);
AcDbCircle *pCircle=new AcDbCircle;
pCircle->setCenter(basePoint);
pCircle->setRadius(1.5);
pCircle->setColorIndex(1); AcDbHatch* pHatch = new AcDbHatch();
AcGeVector3d normal(0.0, 0.0, 1.0);
pHatch->setNormal(normal);
pHatch->setElevation(0.0);
pHatch->setAssociative(Adesk::kTrue);
pHatch->setPattern(AcDbHatch::kPreDefined, "SOLID");
pHatch->setHatchStyle(AcDbHatch::kNormal);
AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForRead);
AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
pBlockTable->close();
AcDbObjectId circleId;
AcDbObjectId hatchId; AcDbObjectIdArray dbObjIds;
pBlockTableRecord->appendAcDbEntity(circleId,pCircle);
dbObjIds.setLogicalLength(0);
dbObjIds.append(circleId);
pHatch->appendLoop(AcDbHatch::kDefault, dbObjIds);
pHatch->evaluateHatch(); dbObjIds.setLogicalLength(0);
pHatch->getAssocObjIds(dbObjIds);
pBlockTableRecord->appendAcDbEntity(hatchId,pHatch); pBlockTableRecord->close();
AcDbEntity *pEnt;
int numObjs = dbObjIds.length();
Acad::ErrorStatus es;
int i;
for (i = 0; i < numObjs; i++) {
es = acdbOpenAcDbEntity(pEnt, dbObjIds, AcDb::kForWrite);
if (es == Acad::eOk) {
pEnt->addPersistentReactor(hatchId);
pEnt->close();
pCircle->close();
pHatch->close(); }
发表于 2004-5-15 15:13:00 | 显示全部楼层
最好用範圍來畫. AcDbHatch* pHatch = new AcDbHatch();
pHatch->setAssociative(Adesk::kFalse);
pHatch->setPatternScale(10.0);
AcGePoint2dArray vertexPts;
AcGeDoubleArray vertexBulges;
vertexPts.setPhysicalLength(0).setLogicalLength(4);
vertexPts[0].set(m_d/2,0);
vertexPts[1].set(0,m_d/2);
vertexPts[2].set(0,0);
vertexPts[3].set(m_d/2,0);
vertexBulges.setPhysicalLength(0).setLogicalLength(4);
vertexBulges[0] = 0.414;
vertexBulges[1] = 0;
vertexBulges[2] = 0;
vertexBulges[3] = 0;
color.setColorIndex(150);
pHatch->setColor(color);
pHatch->appendLoop(AcDbHatch::kExternal, vertexPts, vertexBulges);
pHatch->setPattern(AcDbHatch::kUserDefined, "SOLID"); 代替你畫的部分
 楼主| 发表于 2004-5-16 10:12:00 | 显示全部楼层
关于AcDbHatch的问题?
非常感谢chang,但是我试了你提供的代码仍然没有填充出来,希望给出一段画一个园,并用solid填充的完整代码。
发表于 2004-5-18 09:36:00 | 显示全部楼层
要想用其他的颜色填充怎么实现啊?
发表于 2004-7-14 21:04:00 | 显示全部楼层
补充pHatch-&gt;updateOpen()在close()之前;
发表于 2004-8-7 16:58:00 | 显示全部楼层
你的方法是hatch关联园的ID,但是园没有加到模型空间。也就是说没有ID.当然出现不了hatch。且要加到模型空间
你将我的hatch加到模型空间,就好了。
GMT+8, 2025-10-7 04:17 , Processed in 0.147959 second(s), 23 queries , Gzip On.
