- 积分
- 10518
- 明经币
- 个
- 注册时间
- 2002-6-3
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - Sub Main() ' efan2000编写于2004-05-15
- ' 创建表格样式
- CreateTableStyle
- ' 创建块
- CreateBlock
- ' 创建表格
- CreateTable
- End SubSub CreateTableStyle() Dim DictObj As AcadDictionary
- Set DictObj = ThisDrawing.Database.dictionaries.Item("acad_tablestyle") Dim keyName As String
- Dim className As String
- Dim customObj As AcadTableStyle
- keyName = "明细表"
- className = "AcDbTableStyle"
- Set customObj = DictObj.AddObject(keyName, className)
- ' 表格样式名称
- customObj.Name = "明细表"
- customObj.Description = "明细表表格样式"
- ' 由上而下
- customObj.FlowDirection = acTableBottomToTop
- ' 边距
- customObj.HorzCellMargin = 0
- customObj.VertCellMargin = 0
- ' 取消标题行
- customObj.TitleSuppressed = True
- ' 列标题行,正中对齐,字高为5
- customObj.SetAlignment acHeaderRow, acMiddleCenter
- customObj.SetTextHeight acHeaderRow, 5
- ' 数据行,正中对齐,字高为3.5
- customObj.SetAlignment acDataRow, acMiddleCenter
- customObj.SetTextHeight acDataRow, 3.5
- End SubSub CreateBlock()
- Dim iPt(0 To 2) As Double
- iPt(0) = 0: iPt(1) = 0: iPt(2) = 0
- Dim BlockObj As AcadBlock
- Set BlockObj = ThisDrawing.Blocks.Add(iPt, "明细表-表头")
- iPt(0) = 5: iPt(1) = 10.5: iPt(2) = 0
- Dim MTextObj As AcadMText
- Set MTextObj = BlockObj.AddMText(iPt, 10, "单件")
- MTextObj.Height = 3.5
- MTextObj.AttachmentPoint = acAttachmentPointMiddleCenter
- MTextObj.InsertionPoint = iPt
- iPt(0) = 16: iPt(1) = 10.5: iPt(2) = 0
- Set MTextObj = BlockObj.AddMText(iPt, 12, "总计")
- iPt(0) = 11: iPt(1) = 3.5: iPt(2) = 0
- Set MTextObj = BlockObj.AddMText(iPt, 22, "重量")
- Set MTextObj = Nothing
- Dim sPt(0 To 2) As Double
- Dim ePt(0 To 2) As Double
- sPt(0) = 0: sPt(1) = 7: sPt(2) = 0
- ePt(0) = 22: ePt(1) = 7: ePt(2) = 0
- BlockObj.AddLine sPt, ePt
- sPt(0) = 10: sPt(1) = 14: sPt(2) = 0
- ePt(0) = 10: ePt(1) = 7: ePt(2) = 0
- Set BlockObj = Nothing
- End SubSub CreateTable()
- ' 设置当前表格样式
- ThisDrawing.SetVariable "CTABLESTYLE", "明细表"
- Dim MSpaceObj As IAcadModelSpace2
- Set MSpaceObj = ThisDrawing.ModelSpace
- Dim TableObj As AcadTable
- Set TableObj = MSpaceObj.AddTable(iPt, 2, 8, 7, 10)
- ThisDrawing.SetVariable "CTABLESTYLE", "Standard"
- ' 列标题行,行高为14,其余为7
- TableObj.SetRowHeight 0, 14
- ' 设置列宽
- TableObj.SetColumnWidth 0, 8
- ' 设置单元格文字
- TableObj.SetText 0, 0, "序号"
- TableObj.SetColumnWidth 1, 40
- TableObj.SetText 0, 1, "代 号"
- TableObj.SetColumnWidth 2, 44
- TableObj.SetText 0, 2, "名 称"
- TableObj.SetColumnWidth 3, 8
- TableObj.SetText 0, 3, "数量"
- TableObj.SetColumnWidth 4, 38
- TableObj.SetText 0, 4, "材 料"
- TableObj.SetColumnWidth 5, 10
- TableObj.SetColumnWidth 6, 12
- ' 合并,重量栏
- TableObj.MergeCells 0, 0, 5, 6
- ' 插入块,重理栏
- TableObj.SetBlockTableRecordId 0, 5, ThisDrawing.Blocks("明细表-表头").ObjectID, True
- TableObj.SetCellAlignment 0, 5, acTopCenter
- TableObj.SetColumnWidth 7, 20
- TableObj.SetText 0, 7, "备注"
- ' 数据行
- TableObj.SetText 1, 0, "1"
- End Sub
