查看: 1540|回复: 3
初学者求助
发表于 2004-5-18 22:57:00 | 显示全部楼层 |阅读模式
(defun c:test()
(setq f (open "e:\\abc.txt" "r"))
(setq t1 (read (read-line f)))
(setq t2 (read (read-line f)))
(command "line" "0,t1" "0,t2" "")
(close f)
其中abc.txt   100  t1 200 t2 这个程序在coommand中敲 !t1   为100               !t2   为  200 可就是不能画线,是不是数据类型不对,t1, t2是字符串型的原因,如果是我想把t1 t2 改成另一种类型,怎么改啊,请赐教~.
发表于 2004-5-18 23:10:00 | 显示全部楼层
改为 (command "line" (strcat "0," t1) (strcat "0," t2) "")
发表于 2004-5-19 07:52:00 | 显示全部楼层
<BR>这个程序可能需要做如下改动<BR>1. 在最后加个右括号")"<BR>2. Acad的Line命令后面要点表数据,所以要把<BR>                                 (command "line" "0,t1" "0,t2" "")<BR>                 改为<BR>                         (command "line" (list 0 t1)(list 0 t2) "")<BR>                 这个程序就可画线了。<BR>供参考。<BR>下面是改过的程序:<BR>(defun c:test()<BR>         (setq f (open "e:\\abc.txt" "r"))<BR>         (setq t1 (read (read-line f)))<BR>         (setq         t2 (read (read-line f)))<BR>         (command "line" (list 0 t1)(list 0 t2) "")<BR>         (close f)<BR>         (princ)<BR>)<BR>
发表于 2004-5-19 08:01:00 | 显示全部楼层
這樣也可以,只是轉了n個灣! (command "line"
(strcat "0," (rtos T1))
(strcat "0," (rtos T2))
GMT+8, 2025-8-19 04:26 , Processed in 0.162050 second(s), 26 queries , Gzip On.
