查看: 1658|回复: 0
关于eLockViolation
发表于 2004-5-20 17:16:00 | 显示全部楼层 |阅读模式
es=pBlockTable->getAt()为什么返回值是eLockViolation
代码如下: AcGePoint3d startPoint(165.0,137.0,0.0);
AcGePoint3d endPoint(224.0,216.0,0.0);
//initiate the instance of the line object AcDbLine *pLine=new AcDbLine(startPoint,endPoint);
if(pLine==NULL)
return 0;
//open the blocktable
AcDbBlockTable *pBlockTable;
Acad::ErrorStatus
es=acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable,AcDb::kForRead);
if(es!=Acad::eOk) {
delete pLine;
return 0;
AcDbBlockTableRecord *pBlockTableRecord;
es=pBlockTable->getAt(ACDB_MODEL_SPACE,
pBlockTableRecord,AcDb::kForWrite); 得到的返回值 es为 eLockViolation,该怎么解决啊? 急啊,大侠救我,有些情况下就能得到eOK 的返回值。我是菜鸟!·!·!
GMT+8, 2025-4-18 08:26 , Processed in 0.165138 second(s), 24 queries , Gzip On.
