查看: 2291|回复: 1
难道没人知道吗?
发表于 2002-9-3 21:42:00 | 显示全部楼层 |阅读模式
为什么用(setvar “attreq” 1)(setvar “attdia” 1)(command “insert” “a” b 1 “” “”)a为块名,b为一点,在cad14中可以正常显示块a的属性对话框,而cad2000中则不可以?
发表于 2002-9-4 09:48:00 | 显示全部楼层
前面加一句(initdia 1), 见内
另外,请尽量使用明确一点的标题。不然,很容易被不予理睬。
Forces the display of the next command's dialog box
(initdia [dialogflag])
Currently, the following commands make use of the initdia function: ATTDEF,
ATTEXT, BHATCH, BLOCK, COLOR, IMAGE, IMAGEADJUST, INSERT, LAYER, LINETYPE,
MTEXT, PLOT, RENAME, STYLE, TOOLBAR, and VIEW.
Arguments
dialogflag
An integer. If this argument is not present or is present and nonzero, the
next use (and next use only) of a command will display that command's dialog
box rather than its command line prompts.
If dialogflag is zero, any previous call to this function is cleared,
restoring the default behavior of presenting the command line interface.
GMT+8, 2025-8-10 04:13 , Processed in 0.130153 second(s), 25 queries , Gzip On.
