查看: 1612|回复: 2
为什么总提示参数太少?
发表于 2004-5-26 15:58:00 | 显示全部楼层 |阅读模式
我用啊飞的炸开一个块及子块的程序: (defun Explodex(ents / ss i )
(command "_.explode" ents)
(setq ss (ssget "P"))
(setq i 0)
(repeat (sslength ss)
(setq ent (ssname ss i))
(if (= "INSERT" (cdr (assoc 0 (entget ent))))
(explodex ent)
(setq i (1+ i))
) 改成下面炸开除尺寸线外的块: (defun ExplodexNoDim(ents / ss i Ent1Info Ent1Type)
(setq Ent1Info (entget ents))
(setq Ent1Type (cdr (Assoc 0)))
(if (/= ent1type "DIMENSION")
(Progn
(setq i 0)
(explodex ent)
(setq i (1+ i))
(defun c:ExplodexAllNoDim( / ss i )
(setq ss (ssget "X"))
(setq i 0)
(ExplodexNoDim ent) )
(setq i (1+ i))
) ) 运行后为什么总提示参数太少?
发表于 2004-5-26 16:21:00 | 显示全部楼层
(defun EXPLODEX (ENTS / SS I ENT)
(command "_.explode" ENTS)
(setq SS (ssget "P"))
(setq I 0)
(repeat (sslength SS)
(setq ENT (ssname SS I))
(if (= "INSERT" (cdr (assoc 0 (entget ENT))))
(EXPLODEX ENT)
(setq I (1+ I))
) (defun C:EXPLODEXALLNODIM (/ SS I)
(setq SS (ssget "X"
(list '(0 . "insert") (cons 410 (getvar "ctab")))
(setq I 0)
(EXPLODEX (ssname SS I))
(setq I (1+ I))
 楼主| 发表于 2004-5-27 08:46:00 | 显示全部楼层
今天又试了一下,原来是 (setq Ent1Type (cdr (Assoc 0)))
漏了一个参数,应该为 (setq Ent1Type (cdr (Assoc 0 Ent1Info ))) ,还有其实飞版的程序已经排除了尺寸对象,不用我再加判断。唉!!昨天愣是找不到问题。
GMT+8, 2025-5-14 05:15 , Processed in 0.175275 second(s), 25 queries , Gzip On.
