- 积分
- 520
- 明经币
- 个
- 注册时间
- 2004-4-28
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2004-5-29 22:07:00
显示全部楼层
我设计边界时没有用圆,我只用圆弧和轻便多义线封闭,而且我的同学做他的设计时已经实现。我现在发一个自己任意做实验的程序。这个程序也出现同样的情况。
Private Sub Command1_Click() On Error Resume Next Set acadapp = GetObject(, "AutoCAD.Application") If Err Then Err.Clear Set acadapp = CreateObject("AutoCAD.Application") If Err Then MsgBox ("不能运行AUTOCAD, 请检查是否安装了AUTOCAD") Exit Sub End If End If acadapp.Visible = True
'创建填充对象 Dim hatchobj As AcadHatch Dim patternname As String Dim patterntype As Long Dim bassociativity As Boolean '定义填充 patterntype = 0 patternname = "ANSI31" bassociativity = True '创建填充对象 Set hatchobj = acadapp.ActiveDocument.ModelSpace.AddHatch(patterntype, patternname, bassociativity)
Dim outerloop(0 To 1) As AcadEntity 'Dim innerloop(0 To 0) As AcadEntity
Dim points11(0 To 7) As Double points11(0) = 30 points11(1) = 30 points11(2) = 30 points11(3) = 60 points11(4) = 60 points11(5) = 60 points11(6) = 60 points11(7) = 30 Set outerloop(0) = acadapp.ActiveDocument.ModelSpace.AddLightWeightPolyline(points11)
Dim cen(0 To 2) As Double Dim r As Double Dim startangle As Double Dim endangle As Double cen(0) = 45: cen(1) = 30: cen(2) = 0 r = 15 st = 180 * 3.1415926 / 180 ed = 360 * 3.1415926 / 180 Set outerloop(1) = acadapp.ActiveDocument.ModelSpace.AddArc(cen, r, st, ed)
'向填充对象添加填充边界 hatchobj.AppendOuterLoop (outerloop) 'hatchobj.AppendInnerLoop (innerloop) hatchobj.Evaluate acadapp.ActiveDocument.Regen True ZoomExtents
End Sub
