查看: 1308|回复: 0
紧急求助!!!(怎么用ADO访问Foxpro(*.dbf)数据库!!!!!
发表于 2004-5-29 22:18:00 | 显示全部楼层 |阅读模式
我用以下代码访问但不对,请高手赐教。 Dim MyCn As ADODB.Connection
Dim MyRs As ADODB.Recordset Set MyCn = New ADODB.Connection
Set MyRs = New ADODB.Recordset MyCn.Open "Driver={Microsoft Visual FoxPro Driver};" & _
"SourceType=DBF;" & _
"SourceDB=e:\Data\;" & _
"Exclusive=No;\"
MyRs.Open "select * from Student.dbf", MyCn, adOpenDynamic, adLockReadOnly
GMT+8, 2025-5-26 01:04 , Processed in 0.142655 second(s), 23 queries , Gzip On.
