查看: 1820|回复: 3
怎样用acunion把三个以上的实体合并成一个实体?
发表于 2004-6-1 11:43:00 | 显示全部楼层 |阅读模式
VBA中,怎样用acunion把三个以上的实体合并成一个实体?
比如有solidobj1,solidobj2,solidobj3,solidobj4 ,solidobj5 五个实体
如果这样写,solidobj1.boolean acunion,solidobj2
        solidobj2.boolean acunion,solidobj3
        solidobj3.boolean acunion,solidobj4
        solidobj4.boolean acunion,solidobj5
        对不对?
        请大家指导,谢谢!
发表于 2004-6-1 11:45:00 | 显示全部楼层
Signature
object.Boolean(Operation, Object)
Object
MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_3dsolid_object.htm" target="_blank" >3DSolid, MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_region_object.htm" target="_blank" >Region
The object or objects this method applies to.
Operation
AcBooleanType enum; input-only
acUnion: Performs a union operation.
acIntersection: Performs an intersection operation.
acSubtraction: Performs a subtraction operation.
Object
Object; input-only
The object the operation is performed against.
 楼主| 发表于 2004-6-1 14:08:00 | 显示全部楼层
还是不明白。
发表于 2004-6-1 21:02:00 | 显示全部楼层
布尔运算
用a.Boolean acUnion, b
把b实体合并到a上
GMT+8, 2025-5-26 04:42 , Processed in 0.145264 second(s), 23 queries , Gzip On.
