查看: 3332|回复: 11
请教关于(VL-SORT list comparision-function)函数的用法?
发表于 2004-6-4 14:05:00 | 显示全部楼层 |阅读模式
这个函数是将list表排序并去除重复的元素。但是我用后没有得到这样的结果,请问用这个函数应注意些什么?
我的格式是(VL-SORT c1-item '<) 其中c1-item是我从excel表中读来的一组数据。
发表于 2004-6-4 14:13:00 | 显示全部楼层
看看你的c1-item的内容
 楼主| 发表于 2004-6-4 14:47:00 | 显示全部楼层
c1-item 内容("E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E"
"E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "E" "H" "H" "H" "H" "H" "H"
"H" "H" "H" "H" "H" "H" "H" "H" "H" "K" "K" "K" "K" "K" "K" "K" "K" "K" "K" "K"
"K" "K" "K" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M"
"M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M"
"M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "M" "N" "N" "N" "N"
"N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N" "N"
"N" "N" "P" "P" "P" "P" "P" "P" "P" "P" "P")
发表于 2004-6-4 15:01:00 | 显示全部楼层
这样:(mapcar 'chr (vl-sort (mapcar 'ascii c1-item) '<))
发表于 2004-6-4 15:15:00 | 显示全部楼层
It must be a mistake made by Autodesk.
发表于 2004-6-4 15:22:00 | 显示全部楼层
也不是,在帮助文件中有这样的说明:
返回值
表,其中包含 list 中的元素,这些元素按照 comparison-function 中指定的顺序排列。表中可能删除了重复的元素。
就是没有明确说明哪种情况下会删除重复的元素,这个“可能”太模糊了
发表于 2004-6-4 18:08:00 | 显示全部楼层
指令: (setq a '("1" "2" "1" "3"))
("1" "2" "1" "3") 指令: (vl-sort a '<)
("1" "1" "2" "3") 指令: (setq b '(1 2 1 3))
(1 2 1 3) 指令: (vl-sort b '<)
(1 2 3)
发表于 2004-6-4 18:14:00 | 显示全部楼层
楼上的,想说明什么呢?这几个我也知道啊,我上面的就是把字符转换成数字来排序的,问题是这个规律是什么?哪些会删除重复,哪些不删除,
发表于 2004-6-4 18:19:00 | 显示全部楼层
老大,那是寫給樓主看的,文字,數字,他該會判斷吧
发表于 2004-6-4 20:25:00 | 显示全部楼层
整数,整数,还是整数
  1. (setq a '("1" "2"   "1" "3"))
  2. (vl-sort a '<)
  3. ->("1" "1" "2" "3")
  4. (mapcar 'chr (vl-sort (mapcar 'ascii a) '<))
  5. ->("1" "2" "3") (setq b '(1 2 1 3))
  6. (vl-sort b '<)
  7. ->(1 2 3)(setq b '(1.1 2.1 1.1 3.1))
  8. (vl-sort b '<)
  9. ->(1.1 1.1 2.1 3.1)
  10. (vl-sort b '(lambda(x y)(< (fix x)(fix y))))
  11. ->(1.1 1.1 2.1 3.1)
  12. (mapcar '(lambda(x)(/ x 1e5)) (vl-sort (mapcar '(lambda(x)(fix(* x 1e5))) b) '<))
  13. ->(1.1 2.1 3.1) (setq c '("c" "d"   "a" "b" "a"))
  14. (vl-sort c '<)
  15. ->("a" "a" "b" "c" "d")
  16. (mapcar 'chr (vl-sort (mapcar 'ascii c) '<))
  17. ->("a" "b" "c" "d")
GMT+8, 2025-5-15 12:44 , Processed in 0.188138 second(s), 27 queries , Gzip On.
