查看: 2954|回复: 11
还是直线问题
发表于 2004-6-4 16:26:00 | 显示全部楼层 |阅读模式
问一个简单的问题
lineobj as acadline
lineobj1 as acadline
这样的程序可以实现吗:
lineobj1=thisdrawing.modelspace.addline         (lineobj.startpoint, pt)
就把两点连线然后赋直线给lineobj1,使lineobj1具有lineobj1.startpoint 和lineobj1.endpoint
如果不行,应该怎么做,特急,在线等
发表于 2004-6-4 16:34:00 | 显示全部楼层
你为什么不自己试一下呢?
  1. Sub test()
  2. Dim p1(0 To 2) As Double, p2(0 To 2) As Double
  3. p1(0) = 0
  4. p1(1) = 0
  5. p1(2) = 0
  6. p2(0) = 100
  7. p2(1) = 100
  8. p2(2) = 0
  9. Dim line1 As AcadLine
  10. Set line1 = ThisDrawing.ModelSpace.AddLine(p1, p2)Dim pt(0 To 2) As Double
  11. pt(0) = 100
  12. pt(1) = 50
  13. pt(2) = 0
  14. Set line1 = ThisDrawing.ModelSpace.AddLine(line1.EndPoint, pt)
  15. End Sub
 楼主| 发表于 2004-6-4 17:00:00 | 显示全部楼层
我用过了,这个我知道的 我是在一点程序里运行的,老是在这一段停住了, lineobj1 as acadline For Each entobj3 In objselectionset1
For Each entobj4 In objselectionset4
Set lineobj = entobj3
pt = entobj3.IntersectWith(entobj4, acExtendNone) lineobj1 = ThisDrawing.ModelSpace.AddLine(lineobj.StartPoint, pt) 错误提示内容为:对象变量或with块变量未设置 在程序里我从没用过with块,你可以知道大概是哪里有问题吗?》
发表于 2004-6-4 17:02:00 | 显示全部楼层
贴多一点代码给大家看看吧。
 楼主| 发表于 2004-6-4 17:11:00 | 显示全部楼层
我做的是关于剪切线段的代码 比如说有4条直线成井字放置,长短都不一样, 我想把交点之间的线段都剪掉, 编了下面部分代码
flog = True
If flog = True Then
lineobj2 = ThisDrawing.ModelSpace.AddLine(lineobj.EndPoint, pt)
flog = False
Else
lineobj3 = ThisDrawing.ModelSpace.AddLine(lineobj.StartPoint, pt)
lineobj4 = ThisDrawing.ModelSpace.AddLine(lineobj.EndPoint, pt)
If Sqr((lineobj1.StartPoint(0) - lineobj1.EndPoint(0)) ^ 2 + (lineobj1.StartPoint(1) - lineobj1.EndPoint(1)) ^ 2) < Sqr((lineobj3.StartPoint(0) - lineobj3.EndPoint(0)) ^ 2 + (lineobj3.StartPoint(1) - lineobj3.EndPoint(1)) ^ 2) Then
lineobj3.Delete
Else: lineobj1.Delete
End If
If Sqr((lineobj2.StartPoint(0) - lineobj2.EndPoint(0)) ^ 2 + (lineobj2.StartPoint(1) - lineobj2.EndPoint(1)) ^ 2) < Sqr((lineobj4.StartPoint(0) - lineobj4.EndPoint(0)) ^ 2 + (lineobj4.StartPoint(1) - lineobj4.EndPoint(1)) ^ 2) Then
lineobj2.Delete
Else: lineobj4.Delete
End If
flog = True
End If
Next
entobj3.Delete
Next
其中objselectionset1为两条横放直线,objselectionset2为两条竖放直线
发表于 2004-6-4 17:15:00 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=20823&replyID=20295&skin=1 这里efan2000不是给你了吗?不过长度差距突出的话有点问题。
 楼主| 发表于 2004-6-4 17:19:00 | 显示全部楼层
每次运行到 lineobj1 = ThisDrawing.ModelSpace.AddLine(lineobj.StartPoint, pt)
的时候就会提示错误:对象变量或with块变量未设置
能不能帮我改一下程序,在线等
 楼主| 发表于 2004-6-4 17:34:00 | 显示全部楼层
不知道删除已经addline的直线,用lineobj1.delet可以删除图里的直线吗
如果不能应该用什么方法删除图里的直线啊!我想先问这个
发表于 2004-6-4 17:47:00 | 显示全部楼层
你一试不就知道了吗?你试试有无line1.Delete 这句话的运行结果
  1. Sub test()
  3. p1(0) = 0
  4. p1(1) = 0
  5. p1(2) = 0
  6. p2(0) = 100
  7. p2(1) = 100
  8. p2(2) = 0
  11. pt(0) = 100
  12. pt(1) = 50
  13. pt(2) = 0
  14. Dim line2 As AcadLine
  15. Set line2 = ThisDrawing.ModelSpace.AddLine(line1.EndPoint, pt)line1.Delete  '你试试有无这句话的运行结果End Sub
发表于 2004-6-4 19:39:00 | 显示全部楼层
关键是IntersectWith方法取得的结果是数组,而不是单纯的一个点。多看看帮助文件吧。
GMT+8, 2025-5-26 05:14 , Processed in 0.160022 second(s), 24 queries , Gzip On.
