查看: 1659|回复: 4
[讨论]这种按钮的制作
发表于 2004-6-9 13:00:00 | 显示全部楼层 |阅读模式
大家看到我在点“关”按钮的时候,为什么“关”按钮没有置为当前呢?
这种按钮怎么做?
发表于 2004-6-9 13:10:00 | 显示全部楼层
Use _othericon as the keyword of icon in your menu file
Toolbar flyout definitions in the MNU file contain the keyword Flyout followed by options that are contained in parentheses.
TAG3 [Flyout ("flyname", id_small, id_large, icon, alias)]macro
The options are as follows:
flyname
The string that names the flyout. The string must include alphanumeric characters with no punctuation other than a hyphen (-) or an underscore (_). This string is displayed as a tooltip when the cursor is placed over the flyout.
id_small
The string that names the ID string of the small-image resource (16 × 15 bitmap). The string must include alphanumeric characters with no punctuation other than a hyphen (-) or an underscore (_). This can also specify a user-defined bitmap (see MSITStore:C:\Program%20Files\Autodesk%20Map%202004\help\acad_acg.chm::/acg_0491.html#398573" target="_blank" >Specify User-Defined Bitmaps.
id_big
The string that names the ID string of the large-image resource (32 × 30 bitmap). If the specified bitmap is not 32 × 30, AutoCAD scales it to that size. The string must include alphanumeric characters with no punctuation other than a hyphen (-) or an underscore (_). It can also specify a user-defined bitmap (see MSITStore:C:\Program%20Files\Autodesk%20Map%202004\help\acad_acg.chm::/acg_0491.html#398573" target="_blank" >Specify User-Defined Bitmaps.
icon
The keyword that controls whether to display either its own icon or the last icon selected (other). The acceptable values, OwnIcon and OtherIcon, are not case-sensitive.
alias
The reference to the toolbar to display as the flyout. The alias refers to a toolbar submenu defined with the standard **aliasname syntax.
macro
The menu item macro. It follows the standard menu macro syntax.
See Also
MSITStore:C:\Program%20Files\Autodesk%20Map%202004\help\acad_acg.chm::/acg_0479.html#391560" target="_blank" >Create Toolbars
发表于 2004-6-9 13:34:00 | 显示全部楼层
aaddff发表于2004-6-9 13:00:00回复:(aaddff)这种按钮的制作 8176 大家看到我在点“关”按钮的时候,为什么“关”按钮没有置为当前呢...
你看 dat\press.mnu 文件
发表于 2004-6-9 13:40:00 | 显示全部楼层
在定义下拉工具栏的时候用_OwnIcon时,点击下拉工具栏中不同的按钮,其默认值不会变总是第一个,用_otherIcon时下拉工具栏中的默认值会随你按的按钮而变化。
 楼主| 发表于 2004-6-9 14:02:00 | 显示全部楼层
可以了,还有改下bmp名字
谢谢大家
GMT+8, 2025-2-21 03:52 , Processed in 0.156982 second(s), 26 queries , Gzip On.
