查看: 2543|回复: 11
一个LSP程序的问题?
发表于 2004-6-14 13:08:00 | 显示全部楼层 |阅读模式
这是一个求和的程序,在R14下运行没问题,为什么加载到2002下就不能用了呢?提示:"要绑定的对象不正确: T"
高手帮帮我啊!我在此谢了! (DEFUN C:gross(/ p1 p2)
(command "osnap" "")
(if (not i) (setq i (GETREAL "\n比例<1:x> x: ")))
(princ "请输入计算精度? <2>")
(setq pnumber (getint " "))
(if (not pnumber) (setq pnumber 2))
(setq p1 (getpoint "\nfirst point of the cross "))
(setq p2 (getcorner p1 "\nsecond point of the cross "))
(gross1)
(setq p1 (getpoint "\nwhere to write the weighth?"))
(setq txth (* i 3.5))
(command "text" p1 txth "0" txt)
发表于 2004-6-14 13:36:00 | 显示全部楼层
(gross1)呢?
发表于 2004-6-14 13:41:00 | 显示全部楼层
这个(gross1)的函数我不知出自哪里?
发表于 2004-6-14 13:45:00 | 显示全部楼层
眨了以下眼版主先回了,我多此一举!
 楼主| 发表于 2004-6-14 14:14:00 | 显示全部楼层
高手帮帮我啊!我在此谢了!
(gross1)
(defun gross1(/ nne nn ss0 s ss)
(setq s (ssget "c" p1 p2))
(setq kk 0)
(setq nne (sslength s))
(setq nn 0 ss0 0)
(while (< nn nne)(progn
(setq s0 (ssname s nn))
(setq s1 (entget s0))
(setq ss1 (assoc '10 s1))
(setq s1 (assoc '1 s1))
(if s1 (progn
(setq s1 (cdr s1))
(setq ss1 (cdr ss1))
(setq s1(point s1))
(setq ss (atof s1))
(if (/= ss 0) (progn (grdraw ss1 (polar ss1 (/ pi 5) (* 8 i)) 1 1) (setq kk (+ kk 1)) (princ "+")(princ ss)))
(setq ss0 (+ ss0 ss))))
(setq nn (+ nn 1))))
(setq txt (rtos ss0 2 pnumber))
(progn (princ "\n共有")(princ kk)(Princ "数相加"))
发表于 2004-6-14 16:02:00 | 显示全部楼层
(point s1)
point呢?
 楼主| 发表于 2004-6-14 17:26:00 | 显示全部楼层
发表于 2004-6-14 17:34:00 | 显示全部楼层
问的是point函数,这里(point s1)是函数point,参数s1,这个point函数是自定义函数
 楼主| 发表于 2004-6-15 08:44:00 | 显示全部楼层
哦,不好意思,是这个: (defun point(x / pp xx t)
(setq pp (strlen x) t 1)
(while (< t pp)
(if (= (substr x t 1) ";")
(setq x (substr x (+ t 1)) t pp))(setq t (+ t 1))
(while (< t pp)
(setq xx (substr x t 2))
(if (= xx "。")
(progn (setq x (strcat (substr x 1 (- t 1)) "." (substr x (+ t 2))) t pp))
)(setq t (+ t 1))
)(setq x x)
) 在VISUAL LISP测试: 警告: 内置符号的重定义: T 小弟是菜鸟,请斑竹指点迷津!谢了!
发表于 2004-6-15 09:17:00 | 显示全部楼层
t是系统保留字符,你不能给它重定义,就像setq、if一样,T是不能作为变量的
(setq t (+ t 1))这里的T要换成别的变量(如果别的地方有,或有类似的,都要换掉)
GMT+8, 2025-5-14 16:18 , Processed in 0.178773 second(s), 26 queries , Gzip On.
