查看: 2194|回复: 2
(slide_image x1 y1 width height sldname)里的SLDNAME是什么格式?
发表于 2004-6-15 15:35:00 | 显示全部楼层 |阅读模式
Arguments
x1
X-offset from the upper-left corner of the tile, in pixels. Must be a positive value.
y1
Y-offset from the upper-left corner of the tile, in pixels. Must be a positive value.
width
Width of the image, in pixels.
height
Height of the image, in pixels.
sldname
Identifies the slide. This argument can be a slide file (.sld) or a slide in a slide library file (.slb). Specify sldname the same way you would specify it for the VSLIDE command or for a menu file (see the MSITStore:C:\Program%20Files\AutoCAD%202002\help\acad_vlr.chm::/vldev12.html#17916" target="_blank" > Creating Images topic in the Visual LISP Developer's Guide). Use one of the following formats for sldname:
sldname or libname(sldname)
请问我的*.DWG文件能转换成*.SLD,*.SLB文件吗?
如果能有什么办法?
如果不能,请问在打开DWG时右边有个PREVIEW是怎么做出来的?
我想呀想,就是想不出结果。
发表于 2004-6-15 16:22:00 | 显示全部楼层
SLDNAME 是幻灯片文件 (*.sld)
mslide 命令可以将 DWG 文件保存为 *.SLD
 楼主| 发表于 2004-6-15 16:56:00 | 显示全部楼层
谢谢!
GMT+8, 2024-11-28 10:44 , Processed in 0.168199 second(s), 25 queries , Gzip On.
