查看: 2246|回复: 2
[求教]拜求用设置CAD填充比例的代码
发表于 2004-6-18 12:13:00 | 显示全部楼层 |阅读模式
求代码  我写的是: Public Function AddHatchPt(ByRef ptArr() As Double, ByVal patType As Integer, ByVal patName As String, _
ByVal associativity As Boolean) As AcadHatch
Dim objPline As AcadLWPolyline
If (UBound(ptArr) + 1) Mod 2 <> 0 Then
MsgBox "数组个数必须为偶数"
Exit Function
End If
Set objPline = AcadDoc.ModelSpace.AddLightWeightPolyline(ptArr)
objPline.Closed = True
Dim objList(0) As AcadEntity
Set objList(0) = objPline
Set AddHatchPt = AddHatch(objList, patType, patName, associativity) 只有patType, patName, associativity 预设是1.0  小弟想设定为75 ,求代码 谢谢
发表于 2004-6-18 12:16:00 | 显示全部楼层
AddHatchPt.PatternScale = 75
 楼主| 发表于 2004-6-18 12:18:00 | 显示全部楼层
谢谢斑竹
GMT+8, 2025-9-3 02:06 , Processed in 0.175237 second(s), 23 queries , Gzip On.
