查看: 2287|回复: 1
如何用vba来判断两直线是否相交?
发表于 2004-6-19 10:22:00 | 显示全部楼层 |阅读模式
如何用vba来判断两直线是否相交,若相交,得出交点坐标,
我是新手,望各位前辈多多指教,谢谢!
MAIL:gujian@sohbicn.com
发表于 2004-6-19 13:53:00 | 显示全部楼层
使用直线对象的IntersectWith方法,参看帮助。
  1. Sub Example_IntersectWith()
  2.        ' This example creates a line and circle and finds the points at
  3.        ' which they intersect.
  4.
  5.        ' Create the line
  6.        Dim lineObj As AcadLine
  7.        Dim startPt(0 To 2) As Double
  8.        Dim endPt(0 To 2) As Double
  9.        startPt(0) = 1: startPt(1) = 1: startPt(2) = 0
  10.        endPt(0) = 5: endPt(1) = 5: endPt(2) = 0
  11.        Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
  12.
  13.        ' Create the circle
  14.        Dim circleObj As AcadCircle
  15.        Dim centerPt(0 To 2) As Double
  16.        Dim radius As Double
  17.        centerPt(0) = 3: centerPt(1) = 3: centerPt(2) = 0
  18.        radius = 1
  19.        Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
  20.        ZoomAll
  21.
  22.        ' Find the intersection points between the line and the circle
  23.        Dim intPoints As Variant
  24.        intPoints = lineObj.IntersectWith(circleObj, acExtendNone)
  25.
  26.        ' Print all the intersection points
  27.        Dim I As Integer, j As Integer, k As Integer
  28.        Dim str As String
  29.        If VarType(intPoints) <> vbEmpty Then
  30.                For I = LBound(intPoints) To UBound(intPoints)
  31.                        str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
  32.                        MsgBox str, , "IntersectWith Example"
  33.                        str = ""
  34.                        I = I + 2
  35.                        j = j + 3
  36.                        k = k + 1
  37.                Next
  38.        End If
  39. End Sub
GMT+8, 2025-5-25 14:50 , Processed in 0.168033 second(s), 24 queries , Gzip On.
