查看: 2291|回复: 12
求助
发表于 2004-6-19 20:33:00 | 显示全部楼层 |阅读模式
怎样把一个整个图层中的图形MIRROR或MOVE
怎么把图形中倒数第N个图形MIRROR 或MOVE
发表于 2004-6-19 20:42:00 | 显示全部楼层
Signature
object.Move Point1, Point2
Object
MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/all_drawing_objects.htm" target="_blank" >All Drawing Objects, MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_attributeref_object.htm" target="_blank" >AttributeReference
The object or objects this method applies to.
Point1
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the first point of the move vector.
Point2
The 3D WCS coordinates specifying the second point of the move vector.
Signature
RetVal = object.Mirror(Point1, Point2)
Object
Point1
The 3D WCS coordinates specifying the first point of the mirror axis.
Point2
The 3D WCS coordinates specifying the second point of the mirror axis.
RetVal
Mirrored object
This object can be one of any MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/all_drawing_objects.htm" target="_blank" >Drawing Objects.
 楼主| 发表于 2004-6-19 20:56:00 | 显示全部楼层
这个我在帮助里看到过
我现在要做的是把倒数第32到最后一个图形,整体移动
或者说把一个图层中的所有图形
发表于 2004-6-19 21:01:00 | 显示全部楼层
用For循环做呀 或SendCommand 参见http://bbs.mjtd.com/forum.php?mod=viewthread&tid=20705
 楼主| 发表于 2004-6-19 21:32:00 | 显示全部楼层
  1. Sub QSelLayerControl()
  2. '程序功能:快速选取一层的所有对象,进行相应的操作
  3.        Dim i   As AcadEntity
  4.        Dim ss As AcadSelectionSet
  5.        Dim ft(0) As Integer, fd(0)
  6.        Dim pLayer As String
  7.        Dim pControl As String
  8.        pLayer = ThisDrawing.Utility.GetString(0, vbCrlLf & "请输入层名:")
  9.        ft(0) = 8: fd(0) = pLayer
  10.        Set ss = ThisDrawing.ActiveSelectionSet
  11.        ss.Clear
  12.        ss.Select acSelectionSetAll, , , ft, fd
  13.        If ss.Count = 0 Then
  14.                ss.Delete
  15.                ThisDrawing.Utility.Prompt "层内没有对象或层不存在!"
  16.        Else
  17.                ThisDrawing.Utility.InitializeUserInput 1, "Move Copy Erase"
  18.                pControl = ThisDrawing.Utility.GetKeyword(vbCr & "请输入操作名[Move(移动)/Copy(复制)/Erase(删除)]:")
  19.                ThisDrawing.SendCommand "." & pControl & vbCr & "p" & vbCr & vbCr
  20.        End If
如果我不需要在CAD中选择等操作,直接在代码中实现.可以吗?
发表于 2004-6-19 22:19:00 | 显示全部楼层
假设pObjs是你程序中获得的实体数组或集合或选择集
  1. For Each i In pObjs
  2.            i.Move Point1, Point2
  3. Next i
复制代码
 楼主| 发表于 2004-6-20 08:19:00 | 显示全部楼层
lzh741206发表于2004-6-19 22:19:00假设pObjs是你程序中获得的实体数组或集合或选择集 For Each i In pObjs i.Move Point1, Point2 Next i
大哥:帮我写完整一点好吗? 先MIRROR后MOVE(层中的所有图形) 急用
发表于 2004-6-20 10:10:00 | 显示全部楼层
Sub MMLayer(ByVal LayerName As String, ByVal p1, ByVal p2, ByVal p3, ByVal p4)
Dim i As AcadEntity
Set ss = ThisDrawing.SelectionSets.Add("*TlsTest*")
ft(0) = 8: fd(0) = LayerName
For Each i In ss
i.Mirror(p1, p2).Move p3, p4
i.Delete
Next i
ErrHandle:
ss.Delete
End Sub
 楼主| 发表于 2004-6-20 10:12:00 | 显示全部楼层
  1. Sub zhouhui1()
  2. Dim layerObj As AcadLayerSet layerObj = ThisDrawing.Layers.Add("ABC")  Dim x As AcadObject
  3. 'x.Color = acByLayer
  4. For Each x In ThisDrawing.ModelSpace
  5.      x.Layer = "ABC"
  6.
  7. ' 指定“ABC”图层的颜色为红色     ' x.Color = acRed
  8.        x.Update
  9. Next xDim point1(0 To 2) As Double
  10.        Dim point2(0 To 2) As Double
  11.        point1(0) = 0: point1(1) = 0: point1(2) = 0
  12.        point2(0) = 2: point2(1) = 0: point2(2) = 0
  13. Dim i As AcadObject
  14. For Each i In layerObj
  15.            i.Move point1, point2
  16. Next iEnd Sub
帮我看看最后几行吧,有问题呀
 楼主| 发表于 2004-6-20 10:17:00 | 显示全部楼层
大哥帮忙呀. 我已经写了上面的程序了,可是运行到For Each i In layerObj 出现错误
GMT+8, 2025-6-13 18:35 , Processed in 0.202237 second(s), 24 queries , Gzip On.
