查看: 1527|回复: 6
关于形位公差!
发表于 2004-6-21 10:27:00 | 显示全部楼层 |阅读模式
请问形位公差在图形界面是对话框的形式,在lisp命令中如何使用?
发表于 2004-6-21 11:36:00 | 显示全部楼层
[I]vla-addtolerance[/I] definitely works
 楼主| 发表于 2004-6-21 14:22:00 | 显示全部楼层
alin,请问vla-系列函数使用时,是不是都必须先加载vl-load-com?
可不可以对vla-addtolerance,举个具体例子。
谢谢!
发表于 2004-6-21 15:17:00 | 显示全部楼层
Just an example. (defun C:test() (vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq mspace (vla-get-modelspace doc)
utility (vla-get-utility doc))
(setq basePnt (vla-getPoint utility nil "\nBase Point: ")
textstring "%%vtol1%%vtol2%%v%%v%%v\n2\n3")
(setq direction (vlax-make-safearray vlax-vbDouble '(0 . 2)))
(vlax-safearray-fill direction '(1 0 0))
(setq toleranceObj (vla-addTolerance mspace textstring basePnt direction))
(vla-put-scalefactor toleranceObj (getvar "DIMSCALE"))
发表于 2004-6-21 23:21:00 | 显示全部楼层
vla-addTolerance 这个函数在帮助中怎么查不到,怎么回事啊?
 楼主| 发表于 2004-6-22 18:44:00 | 显示全部楼层
对,我也同样发现这个问题了。
发表于 2004-6-22 19:21:00 | 显示全部楼层
是从ActiveX and VBA Reference帮助里转化而来的
RetVal = object.AddTolerance(Text, InsertionPoint, Direction)
Object
MSITStore:C:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_modelspace_collection.htm" target="_blank" >ModelSpace Collection, MSITStore:C:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_paperspace_collection.htm" target="_blank" >PaperSpace Collection, MSITStore:C:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_block_object.htm" target="_blank" >Block
The object or objects this method applies to.
Text
String; input-only
The text string for the tolerance.
InsertionPoint
Variant (three-element array of doubles); input-only
The 3D WCS coordinates in the drawing specifying the placement of the tolerance symbol.
Direction
A 3D directional vector specifying the direction of the tolerance symbol.
RetVal
MSITStore:C:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_tolerance_object.htm" target="_blank" >Tolerance object
The newly created Tolerance object.
GMT+8, 2025-2-23 01:32 , Processed in 0.156478 second(s), 25 queries , Gzip On.
