查看: 3599|回复: 0
[讨论]VB.Net的事件处理
发表于 2004-6-22 09:57:00 | 显示全部楼层 |阅读模式
原理,在VBA的窗体激活事件中改变USERS系统变量,VB.Net接收该事件将文档级事件处理激活到当前文档
总觉得不太妥当,有好点的办法么?
VB.Net - Module mTlsCad代码
  1. Private WithEvents pACadApp As AcadApplication = Application.AcadApplication
  2. Private WithEvents pACadDoc As AcadDocument = pACadApp.ActiveDocument
  3. Private Sub pACadApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Object) Handles pACadApp.SysVarChanged
  4. If SysvarName.ToUpper = "*USERS5" Then pACadDoc = pACadApp.ActiveDocument
  5. End Sub
  6. Private Sub pACadDoc_BeginDoubleClick(ByVal PickPoint As Object) Handles pACadDoc.BeginDoubleClick
  7. Dim ss As AcadSelectionSet
  8. ss = pACadDoc.PickfirstSelectionSet
  9. If ss.Count = 0 Then
  10. Exit Sub
  11. ElseIf ss.Count = 1 Then
  12. Select Case ss.Item(0).EntityName
  13. Case "AcDbBlockReference"
  14. If ss.Item(0).HasAttributes Then
  15. pACadDoc.SendCommand("_.eattedit" & vbCr & vbCr & vbCr)
  16. End If
  17. Case "AcDbText", "AcDbMText"
  18. pACadDoc.SendCommand("_.ddedit" & vbCr & vbCr)
  19. Case Else
  20. pACadDoc.SendCommand("_.properties" & vbCr)
  21. End Select
  22. Else
  23. pACadDoc.SendCommand("_.properties" & vbCr)
  24. End If
  25. End Sub
VBA - ThisDrawing代码
  1. Private Sub AcadDocument_Activate()
  2. Dim pUser As String
  3. pUser = ThisDrawing.GetVariable("USERS5")
  4. ThisDrawing.SetVariable "USERS5", str(Now)
  5. ThisDrawing.SetVariable "USERS5", pUser
  6. End Sub
GMT+8, 2025-10-15 04:08 , Processed in 0.123048 second(s), 23 queries , Gzip On.
