查看: 1359|回复: 4
求助
发表于 2004-6-22 15:13:00 | 显示全部楼层 |阅读模式
luo:dialog {
label="Fastener Generation";
initial_focus="fast";
:row{
:column{
:boxed_column { label="Select Fastener:";
:list_box{
value="0";
key="fast";
width=10;
height=10;
fixed_height=true;
:boxed_column { label="Select Size:";
:list_box{
key="fsszls";
fixed_height=true;
width=10;
height=10;
allow_accept=true;
alignment=right;
:column{
:radio_row{ label="Select View";
:radio_button{ label="Top";
key="fastop";
value="1";
:radio_button{ label="Side";
key="fassid";
:boxed_row{ label="Fastener Body/Length";
:toggle{ label="Body";
key="fsbod";
:edit_box{ label="";
key="faslgt";
value="2.00";
:radio_row { label="Blind or Thru";
:radio_button{ label="Blind";
key="fsbli";
:radio_button{ label="Thru";
key="fsthr";
:boxed_column{ label="Select Layer";
:popup_list{ label="Layer:"; key="faslay";}
:boxed_column{ label="Preview";
:image_button{ key="fasimg";
width=6;
height=6;
aspect_ratio=1.0;
color=0
ok_cancel;
errtile;
} ---------------------------------- 我的程序在预览时出错,请哪位大哥指正,
发表于 2004-6-22 15:25:00 | 显示全部楼层
不是提示你少了分号吗???
 楼主| 发表于 2004-6-22 15:33:00 | 显示全部楼层
谢谢大哥,它运行时说63行,好像这不是63行
发表于 2004-6-23 09:19:00 | 显示全部楼层
呵呵,我这里提示说是 110 行
 楼主| 发表于 2004-6-23 09:36:00 | 显示全部楼层
用DCL的编写软件会不会比这个方便?
GMT+8, 2025-2-23 01:54 , Processed in 0.190128 second(s), 26 queries , Gzip On.
