查看: 1814|回复: 7
求助:如何取得3D POLYLINE 线的z坐标?
发表于 2004-6-24 19:49:00 | 显示全部楼层 |阅读模式
求助:
发表于 2004-6-24 20:43:00 | 显示全部楼层
(last (assoc 10 (entget (entnext (car (entsel))))))
发表于 2004-6-24 20:44:00 | 显示全部楼层
ENTNEXT -> 得到VERTEX
 楼主| 发表于 2004-6-29 21:22:00 | 显示全部楼层
谢谢斑竹及alin兄: 不过还是不行啊,下面是我用entget 得到的内容及用list命令查询的结果: Command: li LIST
Select objects: 1 found
Select objects:
POLYLINE Layer: 81100
Space: Model space
Handle = B266
Open space VERTEX Layer: 81100
Space: Model space
Handle = B267
Space
at point, X=27500.000 Y=4312725.325 Z= 129.000 VERTEX Layer: 81100
Space: Model space
Handle = B268
Space
at point, X=27500.004 Y=4312725.322 Z= 129.000 VERTEX Layer: 81100
Space: Model space
Handle = B269
Space
at point, X=27500.777 Y=4312724.685 Z= 129.000
area 3822.495
length 179.901 Command: (setq c (entget (car (entsel))))
((-1 . <Entity name: 51f1090>) (0 . "POLYLINE") (5 . "BE32") (100 .
"AcDbEntity") (67 . 0) (8 . "81100") (100 . "AcDb3dPolyline") (66 . 1) (10 0.0
0.0 0.0) (70 . 8) (40 . 0.0) (41 . 0.0) (210 0.0 0.0 1.0) (71 . 0) (72 . 0) (73
. 0) (74 . 0) (75 . 0)) Z坐标还是的不到啊,再请斑竹帮帮忙啊,怎么得到Z坐标(129.000)啊!
 楼主| 发表于 2004-6-29 21:27:00 | 显示全部楼层
序列10项中找不到Z坐标,显示的都是0啊!
发表于 2004-6-29 21:30:00 | 显示全部楼层
不仅仅用到entget,关键还要用entnext。
发表于 2004-6-29 22:19:00 | 显示全部楼层
(DEFUN Z-VALUE (/ Z EN)
(SETQ EN (car (entsel)))
(IF (ENTNEXT EN)
(WHILE (= (CDR (ASSOC 0 (ENTGET (SETQ EN (ENTNEXT EN))))) "VERTEX")
(SETQ Z (CONS (LAST (assoc 10 (entget EN))) Z))
(REVERSE Z))
 楼主| 发表于 2004-6-30 21:55:00 | 显示全部楼层
谢谢,问题解决了!
GMT+8, 2025-5-14 21:46 , Processed in 0.196686 second(s), 25 queries , Gzip On.
