查看: 1869|回复: 1
spline????
发表于 2004-6-28 22:07:00 | 显示全部楼层 |阅读模式
(defun c:ss(/ cm tc os ot ss )
(setq cm (getvar "cmdecho")
tc(getvar "clayer")
os(getvar "osmode")
ot(getvar "orthomode")
(command "osnap" "off")
(command "ortho" "off")
(setvar "cmdecho" 0)
;;(setq pt(getpoint ""))
(command "spline" (getpoint))
(setq ss(ssget "l"))
(tl ss)
(setvar "cmdecho" cm)
(setvar "osmode" os)
(setvar "orthomode" ot)
) 程序中我想绘完一条spline线,之后在进行其他的语句,可是我写的程序总是运行完后才能绘制spline线,不知道有没有办法实现先绘完spline线,然后再创建选择集?
发表于 2004-6-29 00:12:00 | 显示全部楼层
一个点是汇不成一条SPLINE的,是程序出错了
而且SPLINE画了最后一个点后,还要诺干回车,才能结束此命令,你这样命令没结束,就想做后面的事情,肯定不行,所以是程序出错退出了,而不是先创建选择集再画直线(程序退出,但命令没有退出,所以最后还让你继续画SPLINE)
(command "spline" (getpoint) (getpoint) (getpoint) "" "" "")
GMT+8, 2025-5-14 18:13 , Processed in 0.169080 second(s), 25 queries , Gzip On.
