查看: 2244|回复: 1
清问:AddMLine有哪些参数,类型如何?
发表于 2002-9-15 13:33:00 | 显示全部楼层 |阅读模式
发表于 2002-9-15 22:46:00 | 显示全部楼层
你可以查看ACAD对象的相关帮助,详见正文
Creates multiple lines passing through an array of points.
RetVal = object.AddMLine(VertexList)
Object:        ModelSpace Collection, PaperSpace Collection, Block
          The object or objects this method applies to.
VertexList:Variant (array of doubles); input-only
        An array of the 3D WCS coordinates specifying the vertices for the multiline.
RetVal:MLine object
The newly created MLine object.
For example:
Sub Example_AddMLine()
   ' This example adds an Mline in model space
    Dim mLineObj As AcadMLine
    Dim vertexList(0 To 17) As Double
    ' Define data for new object
    vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
    vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
    vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
    vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
    vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
    vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6
    ' Create the line in model space
    Set mLineObj = ThisDrawing.ModelSpace.AddMLine(vertexList)
    ThisDrawing.Application.ZoomAll
    MsgBox "A new MLine has been added to the drawing."
End Sub
GMT+8, 2025-5-12 18:43 , Processed in 0.225783 second(s), 23 queries , Gzip On.
