查看: 1932|回复: 1
[求助]关于事件的使用
发表于 2004-7-10 23:14:00 | 显示全部楼层 |阅读模式
Public WithEvents PLine As AcadLWPolyline
Sub CreatePLineWithEvents()
' 本例创建一细多义线
Dim points(0 To 9) As Double
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 3
points(8) = 3: points(9) = 2
Set PLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
PLine.Closed = True
Dim pt1(0 To 5) As Double
Dim pt2(0 To 2) As Double
pt1(0) = 0: pt1(1) = 0: pt1(2) = 2
pt1(3) = 2: pt1(4) = 4: pt1(5) = 5
Set PLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(pt1)
PLine.Closed = True ThisDrawing.Application.ZoomAll
End Sub Private Sub PLine_Modified _
(ByVal pObject As AutoCAD.IAcadObject)
On Error GoTo ERRORHANDLER
MsgBox "对象" & pObject.ObjectName & " 的面积为: " _
& pObject.Area
Exit Sub
ERRORHANDLER:
MsgBox Err.Description
End Sub
以上的代码,顺利执行后,只有在图形中改动后来创建的PLine对象,才触发事件。但是改变前一个PLine对象,并不触发。我的要求是创建多个PLine对象,(我试了一下,用数组PLine(0),PLine(1)不行)如何改变任何一个对象,都触发对象改动事件么? 谢谢指教。
发表于 2004-7-11 03:49:00 | 显示全部楼层
这样行不通的,应该启用文档层次的事件AcadDocument_ObjectModified监视所有的图元修改
GMT+8, 2025-5-25 14:46 , Processed in 0.150160 second(s), 23 queries , Gzip On.
