查看: 2540|回复: 0
Excel sheet1被打开,但无"Sheet1"''Line'等字符.程序提示:找不到成员
发表于 2002-9-17 12:56:00 | 显示全部楼层 |阅读模式
Excel sheet1被打开,但无"Sheet1"''Line'等字符.程序提示:找不到成员。请问?[br]下面是 Delphi程序代码
    ExcelAppStr:='Excel.Application';
    ExcelInstalled := True;
    try
      ExcelObj:=GetActiveOleobject(ExcelAppStr);
    except
      on EOleSysError do
          ExcelAlreadyRunning:=false;
    end;
    if not ExcelAlreadyRunning then
      try
        ExcelObj:=CreateOleObject(ExcelAppStr);
      except
        begin
          MessageDlg('没有安装Excel。', mtInformation, [mbok], 0);
          ExcelInstalled := false;
        end;
      end;
    if not ExcelInstalled then Exit ;    // Terminate the Application
     ExcelObj.Visible := True;
     ExcelObj.Workbooks.add;
     ExcelWorkSheet:=ExcelObj.ActiveWorkBook.Sheets('"Sheet1"');
     ExcelWorkSheet.Cells[1,1].value:='Line';
     ExcelWorkSheet.Cells[2,1].value:='Start';
     ExcelWorkSheet.Cells[3,1].value:='End';
程序提示:找不到成员。请问?
GMT+8, 2025-5-23 15:26 , Processed in 0.139497 second(s), 23 queries , Gzip On.
