查看: 2118|回复: 2
如何创建二维坐标系啊?
发表于 2004-7-13 16:26:00 | 显示全部楼层 |阅读模式
如何创建二维坐标系啊? Dim ucsObj As AcadUCS
Dim origin As Variant
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin = ThisDrawing.Utility.GetPoint(, "指定标注原点:") xAxisPoint(0) = origin(0): xAxisPoint(1) = 0: xAxisPoint(2) = 0
yAxisPoint(0) = 0: yAxisPoint(1) = origin(1): yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj 就象在CAD里用UCS命令一样效果。以上程序建立出来的X坐标为什么是反的啊?
发表于 2004-7-13 20:34:00 | 显示全部楼层
xAxisPoint(0) = origin(0)+1: xAxisPoint(1) = origin(1): xAxisPoint(2) = 0
yAxisPoint(0) = origin(0): yAxisPoint(1) = origin(1)+1: yAxisPoint(2) = 0
发表于 2004-7-19 08:58:00 | 显示全部楼层
可以了,非常感谢!
GMT+8, 2025-10-10 04:10 , Processed in 0.127399 second(s), 23 queries , Gzip On.
