查看: 1335|回复: 3
求助,请高手帮我看一下错在那里,谢谢了!
发表于 2004-7-14 18:44:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
UserForm1.Hide
Dim ss As AcadSelectionSet
On Error Resume Next
ThisDrawing.SelectionSets("mccad").Delete
Set ss = ThisDrawing.SelectionSets.Add("mccad")
'对象选择
ThisDrawing.Utility.Prompt vbCr & "请选择复制的对象:"
ss.SelectOnScreen
Dim pa1(0 To 2) As Double
pa1(0) = 0: pa1(1) = 0: pa1(2) = 0
Dim pa2(0 To 2) As Double
pa2(0) = textbox1: pa2(1) = TextBox2: pa2(2) = 0
'进行复制
Dim ent As AcadEntity
If ss.Count > 0 Then
For Each ent In ss
ent.Copy pa1, pa2
Next
End If
发表于 2004-7-14 19:24:00 | 显示全部楼层
pa1,pa2要定义为variant,然后用取得的一个点赋值。不能直接定义为数组。
 楼主| 发表于 2004-7-14 20:17:00 | 显示全部楼层
给个例子好吗!
发表于 2004-7-15 10:50:00 | 显示全部楼层
ent.Copy pa1, pa2
错 应该是 ent.Copy.Move pa1,pa2
GMT+8, 2025-10-10 04:07 , Processed in 0.125744 second(s), 23 queries , Gzip On.
