查看: 1398|回复: 1
请教!
发表于 2004-7-20 09:39:00 | 显示全部楼层 |阅读模式
在制作样板图的时候,为什么总会有一个"定义点"的图层,删除掉它会不会有什么影响,各位,谁知道的不妨告诉小弟,谢谢!
发表于 2004-7-20 12:04:00 | 显示全部楼层
< class=tdtext>                                                 The DEFPOINTS layer is created automatically the first time a dimension is created in a drawing. Because this layer contains information about dimensions, you should never delete the layer because the dimension data in the drawing may become compromised.
< class=tdtext>        -引自“AutoCAD帮助”
GMT+8, 2025-5-18 09:28 , Processed in 0.180842 second(s), 23 queries , Gzip On.
