查看: 5011|回复: 3
如何lisp程序中获取光标所在处点的绝对坐标(不用grread、getpoint等函数)?如果有高
发表于 2002-3-19 20:05:00 | 显示全部楼层 |阅读模式
如何lisp程序中获取光标所在处点的绝对坐标(不用grread、getpoint等函数)?如果有高手请告我知不胜感激[br]如何lisp程序中获取光标所在处点的绝对坐标(不用grread、getpoint等函数)?如果有高手请告我知,不胜感激
发表于 2002-3-19 20:43:00 | 显示全部楼层
winapi.arx中有此函数
The api_cursorpos function retrieves the cursor's position, in screen coordinates.
(api_cursorpos)
Parameters
none
Return Values
Success: a list of integers in the following form (x y)
Failure: nil
Remarks
The cursor position is always specified in screen coordinates and is not affected by the mapping mode of the window that contains the cursor.
Requirements
  Windows NT/2000: Requires Windows NT 3.1 or later.
  Windows 95/98: Requires Windows 95 or later.
 楼主| 发表于 2002-3-20 08:21:00 | 显示全部楼层
请问如何使用?我用的是autolisp ,请问如何调用winapi.arx?
发表于 2002-3-22 22:09:00 | 显示全部楼层
这样加载winapi.arx
把winapi.arx放在Acad的支持路径下,然后八以下代码加入您的程序开头
(IF (NOT (MEMBER "winapi.arx" (ARX)))
    (if (= "winapi.arx not found"
(ARXLOAD "objectdcl.arx" "winapi.arx not found."))
        (exit))
GMT+8, 2025-8-22 04:15 , Processed in 0.162989 second(s), 25 queries , Gzip On.
