查看: 1647|回复: 3
字典到底有什么用?
发表于 2004-7-22 14:52:00 | 显示全部楼层 |阅读模式
谁能说一下字典到底有什么用?谢谢。
发表于 2004-7-22 15:12:00 | 显示全部楼层
Online help ictionaries provide a mechanism for storing and retrieving objects with associated string keywords.
The objects in a dictionary may be referenced by their keywords. A dictionary can contain any type of object, including other dictionaries. A dictionary does not perform type checking of entries.
You can create new dictionaries, add entries to an existing dictionary, and get the keyword for a given object or the object for a given keyword. You can change the object that is associated with a given keyword, or rename the keyword for a given object.
This dictionary is similar to a collection in AutoCAD, and is used for custom object implementation. This object does not represent the spellchecking dictionary. The spellchecking dictionary is specified in the MSITStore:C:\Program%20Files\Autodesk%20Map%202004\help\acadauto.chm::/idh_preferences_object.htm" target="_blank" >Preferences object.
发表于 2004-7-22 15:38:00 | 显示全部楼层
alin发表于2004-7-22 15:12:00Online help ictionaries provide a mechanism for storing and retrieving objects with as...
楼上轻易不讲中文,搞来一堆鸡肠,睇到人都傻哂,不过好有水平!
发表于 2004-7-22 18:50:00 | 显示全部楼层
我只知道可以将数据保存在图档中。
GMT+8, 2025-2-19 06:07 , Processed in 0.151173 second(s), 26 queries , Gzip On.
