查看: 1921|回复: 3
关于两点间距离
发表于 2004-7-25 22:55:00 | 显示全部楼层 |阅读模式
一条由若干直线和弧线首尾相连组成的线上,任意选两个点,怎样才能得到沿这条线的两点间距离,在选择的时候如果不是按照连接的顺序选择,怎么建立这个选择集
发表于 2004-7-25 23:05:00 | 显示全部楼层
  1. (defun c:qxdist  (/ SS DIST DIST1 DIST2 EN ENOBJ OSM P1 P2)
  2.    (vl-load-com)
  3.    (setq ss (ssget))
  4.    (command "pedit" "M" ss "" "" "j" "0" "")
  5.    (setq osm (getvar "OSMode"))
  6.    (setvar "OSMode" 512)
  7.    (setq p1 (getpoint "\n选择第一点:"))
  8.    (setq p2 (getpoint "\n选择第二点:"))
  9.    (setq en (ssname (ssget p1) 0))
  10.    (setq enobj (vlax-ename->vla-object en))
  11.    (setq dist1 (vlax-curve-getDistAtPoint enobj p1))
  12.    (setq dist2 (vlax-curve-getDistAtPoint enobj p2))
  13.    (command "undo" "1")
  14.    (setvar "OSMode" osm)
  15.    (princ "\n测量段曲线长度:")
  16.    (setq dist (abs (- dist1 dist2)))
  17. )
发表于 2004-7-26 02:17:00 | 显示全部楼层
似乎有问题 (command "pedit" "M" ss "" "" "j" "0" "") 是否应改为 (command "pedit" "M" ss "" "j" "0" "")
发表于 2004-7-26 12:49:00 | 显示全部楼层
我在2002下调试没有问题,其它版本没有调试过,不知pedit命令的选项是否有变化。
GMT+8, 2024-11-18 23:45 , Processed in 0.170514 second(s), 25 queries , Gzip On.
