查看: 1597|回复: 1
在vb中使用类来处理事件(帮忙看看如何修改代码)
发表于 2004-7-26 17:21:00 | 显示全部楼层 |阅读模式
类模块eventclassmodule里的代码:
Option Explicit
Public WithEvents Doc As AcadDocument
Public Sub AcadDocument_ObjectModified(ByVal obj As AcadObject)
MsgBox "A " & TypeName(object) & " was just modified!"
End Sub 窗体模块中的代码:
Option Explicit
Dim acadApp As AcadApplication
Dim X As New EventClassModule Private Sub Form_Load()
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application")
If Err Then
MsgBox ("²»ÄÜÔËÐÐAutoCAD2004,Çë¼ì²éÊÇ·ñ°²×°ÁËAutoCAD2004")
Exit Sub
End If
End If
acadApp.Visible = True
acadApp.WindowState = acMax
X.Doc = AcadApplication.ActiveDocument
Dim lineObj As AcadLine
Dim startPoint(0 To 2) As Double
Dim endPoint(0 To 2) As Double
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
Set lineObj = AcadApplication.ActiveDocument.ModelSpace.AddLine(startPoint, endPoint)
Me.Hide
End Sub 请教如何改动,才能够在改动直线时,触发事件?
谢谢指教。
发表于 2004-7-26 21:35:00 | 显示全部楼层
vb里做事件比较痛苦,为什么不用VBA呢?
GMT+8, 2025-5-26 12:03 , Processed in 0.202247 second(s), 23 queries , Gzip On.
