查看: 1318|回复: 1
看看什么问题
发表于 2004-7-28 13:14:00 | 显示全部楼层 |阅读模式
Sub Ch9_SwitchToPaperSpace()
' Set the active space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paperspace viewport
Dim newVport As AcadPViewport
Dim center(0 To 2) As Double
center(0) = 3.25
center(1) = 3
center(2) = 0
Set newVport = ThisDrawing.PaperSpace. _
AddPViewport(center, 6, 5)
' Change the view direction for the viewport
Dim viewDir(0 To 2) As Double viewDir(0) = 1
viewDir(1) = 1
viewDir(2) = 1
newVport.direction = viewDir
' Enable the viewport
newVport.Display True
' Switch to model space
ThisDrawing.MSpace = True
' Set newVport current
' (not always necessary but a good idea)
ThisDrawing.ActivePViewport = newVport
' Zoom Extents in model space
ZoomExtents
' Turn model space editing off ThisDrawing.MSpace = False
' ZoomExtents in paperspace
ZoomExtents End Sub 是什么问题啊
发表于 2004-7-28 22:12:00 | 显示全部楼层
你的程序有什么问题呀?
GMT+8, 2025-5-26 11:55 , Processed in 0.175693 second(s), 23 queries , Gzip On.
