- 积分
- 348
- 明经币
- 个
- 注册时间
- 2004-5-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2004-8-2 14:41:00
显示全部楼层
代码如下:
Sub rename() '定义变量 Dim elem As Object '定义一个对象 Dim varAttributes As Variant '定义一个属性变量 Dim OldName As String Dim NewName As String Dim CgName As String Dim L As Integer Dim LL As Integer Dim LLL As Integer Dim number As Integer Dim I As Integer Dim found As Boolean Static sset As AcadSelectionSet Dim sss1 As AcadSelectionSet Dim ObjSelectionSet As AcadSelectionSet found = False I = 0 '获取当前文件名 NewName = ThisDrawing.Name L = Len(NewName) NewName = Left(NewName, L - 4) '获取当前文档标题栏中的图号 On Error Resume Next Dim fft(1) As Integer, ffd(1) ThisDrawing.SelectionSets("ss").Delete Set sset = ThisDrawing.SelectionSets.Add("ss") fft(0) = 0: ffd(0) = "Insert" fft(1) = 2: ffd(1) = "PC_TITLE_BLOCK" sset.Select acSelectionSetAll, , , fft, ffd varAttributes = sset.Item(0).GetAttributes OldName = varAttributes(4).TextString '选择明细表 On Error Resume Next Dim ss1 As AcadSelectionSet Dim ft(1) As Integer, fd(1) ThisDrawing.SelectionSets("*TlsTest*").Delete Set ss1 = ThisDrawing.SelectionSets.Add("*TlsTest*") ft(0) = 0: fd(0) = "Insert" ft(1) = 2: fd(1) = "PC_MXB_BLOCK" ss1.Select acSelectionSetAll, , , ft, fd '修改明细表和标题 For Each elem In ss1 varAttributes = elem.GetAttributes CgName = varAttributes(1).TextString L = Len(NewName) LL = Len(OldName) LLL = Len(CgName) If OldName = Left(CgName, LL) Then CgName = Right(CgName, LLL - LL) CgName = NewName & CgName varAttributes(1).TextString = CgName elem.Update End If Next For Each elem In sset varAttributes = elem.GetAttributes varAttributes(4).TextString = NewName Next '删除标题栏和明细表选择集 ThisDrawing.SelectionSets("*TlsTest*").Delete ThisDrawing.SelectionSets("ss").Delete End Sub
举例说明一下该代码主要目的:
有一dwg文件,文件保存为ZJ40DBST,则文件的图样代号也为ZJ40DBST,明细表中代号也以ZJ40DBST开头来排序,但当我想把ZJ40DBST改为ZJ70LDB时,只需改一下保存的文件名,然后打开ZJ70LDB文件,运行上面的代码即可,但修改是针对天河PCCAD2002所写代码,故需在PCCAD2002下才能发现该情况,谢谢! |
