查看: 1553|回复: 0
块参照问题
发表于 2004-8-3 22:15:00 | 显示全部楼层 |阅读模式
Sub Example_Bind()
On Error GoTo ERRORHANDLER
' Define external reference to be inserted
Dim xrefHome As AcadBlock
Dim xrefInserted1 As AcadExternalReference
Dim xrefInserted2 As AcadExternalReference
Dim insertionPnt(0 To 2) As Double
Dim PathName As String
insertionPnt(0) = 1
insertionPnt(1) = 1
insertionPnt(2) = 0
PathName = "e:/lgs/ER1.dwg"
' Add the external reference
Set xrefInserted1 = ThisDrawing.ModelSpace. _
AttachExternalReference(PathName, "XREF_IMAGE", _
insertionPnt, 1, 1, 1, 90, False)
Set xrefInserted2 = ThisDrawing.ModelSpace. _
insertionPnt, 1, 1, 1, 0, False)
ZoomAll
MsgBox "The external reference is attached."
' Bind the external reference definition
ThisDrawing.Blocks.Item(xrefInserted1.Name).Bind False
'ThisDrawing.Blocks.Item(xrefInserted2.Name).Bind False
MsgBox "The external reference is bound."
Exit Sub
ERRORHANDLER:
MsgBox Err.Description
End Sub 为什么不要ThisDrawing.Blocks.Item(xrefInserted1.Name).Bind False就可以在一个CAD窗口多次运行程序? 但采用ThisDrawing.Blocks.Item(xrefInserted1.Name).Bind False却不能在同一个CAD窗口多次运行程序,是不是该CAD图块文件被独占打开,而没有关闭。有什么办法不去掉该语句并能解决这个问题吗? 先谢谢大侠!
GMT+8, 2025-9-3 07:52 , Processed in 0.228094 second(s), 23 queries , Gzip On.
