查看: 1253|回复: 0
多边形转化为CP区域选择的问题
发表于 2004-8-6 11:37:00 | 显示全部楼层 |阅读模式
Sub Test()
Dim ssetObj As AcadSelectionSet
Dim CC As AcadCircle
Dim points(59) As Double Dim retCoord As Variant
Dim pntcnt As Integer On Error Resume Next
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET2") On Error GoTo ErrHandle
Dim pFrom, pTo
Dim p1(3) As Double, p2(1) As Double
Dim pPL As AcadLWPolyline
pFrom = ThisDrawing.Utility.GetPoint(, vbCr & "Pls Input First Point:")
pTo = ThisDrawing.Utility.GetPoint(pFrom, vbCr & "Pls Input Second Point")
p1(0) = pFrom(0): p1(1) = pFrom(1)
p1(2) = pTo(0): p1(3) = pTo(1)
Set pPL = ThisDrawing.ModelSpace.AddLightWeightPolyline(p1)
Do While True
pTo = ThisDrawing.Utility.GetPoint(pTo, vbCr & "Pls Input Next Point")
p2(0) = pTo(0): p2(1) = pTo(1)
pPL.AddVertex (UBound(pPL.Coordinates) + 1) / 2, p2
Loop
ErrHandle:
pPL.Closed = True 'points = pPL.Coordinates
retCoord = pPL.Coordinates
pntcnt = UBound(retCoord)
Dim i As Integer
Dim j As Integer
'Dim points As Double
i = 0
Dim dip As String
For j = 0 To pntcnt - 1 Step 2
points(i) = retCoord(j)
points(i + 1) = retCoord(j + 1)
points(i + 1) = 0
i = i + 3
Next j
Dim m As Integer
ssetObj.SelectByPolygon acSelectionSetCrossingPolygon, points For Each CC In ssetObj On Error Resume Next CC.color = acBlue
CC.Update
Next CC
ssetObj.Clear
ssetObj.Erase
ssetObj.Delete
End Sub 此程序是在随风大侠的帮助下编写的多线段定义的多边形转化为CP区域选择的问题,但是在运行中会出现“Run-time error“91”: Object variable or With block variable not set” 请大侠帮我修改与完善次代码,本人涕泪感激!
GMT+8, 2025-9-3 07:50 , Processed in 0.160742 second(s), 23 queries , Gzip On.
