- 积分
- 10054
- 明经币
- 个
- 注册时间
- 2004-6-10
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
[VBA]如何利用vba提取polyline中各顶点的坐标?亿万分感谢!
下面这段程序只能获得坐标,只能获得第一个点的高程,无法获得每个点的高程。
Sub RevPline() Dim ent As AcadEntity Dim pnt As Variant Dim NewCoord() As Double Dim i As Integer On Error Resume Next Do ThisDrawing.Utility.GetEntity ent, pnt, "选择多段线:" If Err Then Exit Sub If TypeName(ent) Like "IAcad*Polyline" Then Exit Do Loop Dim Coord As Variant Dim CoordCount As Integer Dim Bulge() As Double '凸度 If TypeName(ent) = "IAcadLWPolyline" Then Coord = ent.Coordinates '获取顶点坐标数组 CoordCount = (UBound(Coord) + 1) / 2 '顶点数 '定义新的顶点坐标数组 ReDim NewCoord(UBound(Coord)) As Double For i = 0 To UBound(Coord) - 1 Step 2 NewCoord(UBound(Coord) - i - 1) = Coord(i) NewCoord(UBound(Coord) - i) = Coord(i + 1) Next ReDim Bulge(CoordCount - 1) As Double For i = 0 To CoordCount - 1 Bulge(i) = ent.GetBulge(i) Next ent.Coordinates = NewCoord For i = 0 To CoordCount - 2 ent.SetBulge i, -Bulge(CoordCount - 2 - i) Next ThisDrawing.Regen acActiveViewport ElseIf TypeName(ent) = "IAcadPolyline" Then Coord = ent.Coordinates CoordCount = (UBound(Coord) + 1) / 3 ReDim NewCoord(UBound(Coord)) As Double For i = 0 To UBound(Coord) - 1 Step 3 NewCoord(UBound(Coord) - i - 2) = Coord(i) NewCoord(UBound(Coord) - i - 1) = Coord(i + 1) NewCoord(UBound(Coord) - i) = Coord(i + 2) Next If ent.Type = acSimplePoly Then ReDim Bulge(CoordCount - 1) As Double For i = 0 To CoordCount - 1 Bulge(i) = ent.GetBulge(i) Next End If ent.Coordinates = NewCoord If ent.Type = acSimplePoly Then For i = 0 To CoordCount - 2 ent.SetBulge i, -Bulge(CoordCount - 2 - i) Next End If ThisDrawing.Regen acActiveViewport End If End Sub
