查看: 2261|回复: 3
请问怎样读取属性块中的数据 并修改
发表于 2004-8-11 15:50:00 | 显示全部楼层 |阅读模式
回答《请问怎样读取属性块中的数据》之高手,请问如何在此基础上修改属性值,我试过ENTMOD,ENTUPD屏幕都没改,但改动属性值中的提示却可以,
发表于 2004-8-11 23:38:00 | 显示全部楼层
我写过Visual Lisp的代码,明天上传.
发表于 2004-8-12 09:01:00 | 显示全部楼层
;;actj2k是块名,L1,L2等是属性标记(Tag)
(vl-load-com) (defun c:mychange ( / ss item blk)
(if (setq ss (vlex-SelectOnScreen-Filter (list 0 2)(list "INSERT" "actj2tk")))
(vlax-For item ss
(if (equal (type item) 'vla-object)
(setq blk (vlax-vla-object->Ename item))
(setq blk item)
(vlex-ChangeAttributes (list blk (cons "L1" "a")))
(vlex-ChangeAttributes (list blk (cons "L2" "b")))
(vlex-ChangeAttributes (list blk (cons "R3" "c")))
(terpri)
) (defun vlex-SSetExists-p (Name)
(not
(vl-Catch-All-Error-p
(vl-Catch-All-Apply
'vla-Item
(list (vla-Get-SelectionSets (vlex-ActiveDocument)) Name)
) (defun vlex-SelectOnScreen-Filter (GroupCodes FilterLists / ss)
(if (vlex-SSetExists-p "%TEMP_SET")
(vla-Delete
(vla-Item
(vla-get-SelectionSets (vlex-ActiveDocument))
"%TEMP_SET"
(setq ss
(vla-Add
"%TEMP_SET"
(vla-Select ss
ACSelectionSetAll nil nil
(vlex-IntList->VarArray GroupCodes)
(vlex-VarList->VarArray FilterLists)
ss
) (defun vlex-VarList->VarArray (aList)
(vlax-SafeArray-Fill
(vlax-Make-SafeArray
vlax-vbVariant ;(12) Variant
(cons 0 (- (length aList) 1))
aList
) (defun vlex-IntList->VarArray (aList)
vlax-vbInteger ; (2) Integer
aList
) (defun vlex-ChangeAttributes (lst / blk item atts)
(setq blk (vlax-Ename->vla-Object (car lst))
lst (cdr lst)
(if (= (vla-Get-HasAttributes blk) :vlax-true)
(setq atts (vlax-SafeArray->list
(vlax-Variant-Value (vla-GetAttributes blk))
); setq
(foreach item lst
(mapcar
'(lambda (x)
(if (= (strcase (car item)) (strcase (vla-Get-TagString x)))
(vla-Put-TextString x (cdr item))
); endif
atts
); mapcar
); foreach
(vla-Update blk)
); endif
) (defun vlex-ActiveDocument ()
(vla-Get-ActiveDocument (vlax-get-acad-object))
 楼主| 发表于 2004-8-12 12:26:00 | 显示全部楼层
(Defun Si (/ slist sname etbll)
(setq sliST (entget (ssname (ssget) 0)))
(SetQ sname (Cdr (Assoc 2 sliST)) sli (TblSearch "BLOCK" sname) )
(SetQ sname (Cdr (Assoc -2 sliST)))
(While sname
(setq slist (entget sname))
(if (/= (cdr (assoc 3 slist)) nil)
(SETQ slist(SUBST (cons 1 "bbbb") (assoc 1 slist) slist))
(ENTMOD slist)
(entupd sname)
(setq sname (EntNext sname))
;(entupd sli)
屏幕没刷新
GMT+8, 2025-5-15 06:10 , Processed in 0.173223 second(s), 26 queries , Gzip On.
