查看: 1825|回复: 2
错误提示
发表于 2004-8-14 18:36:00 | 显示全部楼层 |阅读模式
请大虾们帮我看看,为什么会提示:
此类型的 LISP值不能强制转换成 VARIANT:
发表于 2004-8-14 19:23:00 | 显示全部楼层
(defun c:test (/ layersel clfspt av_la CenLine pt)
(vl-load-com)
(setq AcadObject (vlax-get-acad-object)
AcadDocument (vla-get-ActiveDocument AcadObject)
mSpace (vla-get-ModelSpace AcadDocument)
(setq av_la (null (tblsearch "layer" "center"))
layersel (vla-get-layers AcadDocument)
clfspt (getpoint "\nPick")
;;; (if (= av_la T) (setq new_layer (vla-add layersel "Center")))
(setq pt (getpoint clfspt "\nPick end: "))
(setq CenLine (vla-addline mSpace (vlax-3d-point clfspt) (vlax-3d-point pt))) ;***
 楼主| 发表于 2004-8-16 07:58:00 | 显示全部楼层
谢谢!!
GMT+8, 2025-7-29 11:32 , Processed in 0.197956 second(s), 26 queries , Gzip On.
