查看: 1398|回复: 1
求教
发表于 2004-8-15 18:23:00 | 显示全部楼层 |阅读模式
请大家帮我看看这多代码有什么问题,为什么说类型不匹配啊 Public Sub ext()
Dim pt(5) As Double
Dim objpline As Acad3DPolyline
pt(0) = 100
pt(1) = 200
pt(2) = 300
pt(3) = 100
pt(4) = 200
pt(5) = 800
Set objpline = ThisDrawing.ModelSpace.Add3DPoly(pt)
objpline.color = acGreen
Dim objlist(0) As AcadEntity
Dim ptcen(2) As Double
ptcen(0) = 100
ptcen(1) = 200
ptcen(2) = 300
Set objlist(0) = ThisDrawing.ModelSpace.AddCircle(ptcen, 50)
Dim objregion As Variant
Set objregion = ThisDrawing.ModelSpace.AddRegion(objlist)
Dim objsolid As Acad3DSolid
Set objsolid = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(objregion(0), objpline)
ZoomExtents
End Sub
发表于 2004-8-15 18:37:00 | 显示全部楼层
改为
注意不是对象不能用Set
GMT+8, 2025-5-26 10:14 , Processed in 0.153190 second(s), 23 queries , Gzip On.
