查看: 2439|回复: 5
[讨论]如何获得一个对象其正确的在UCS中的边界坐标?
发表于 2004-8-19 09:41:00 | 显示全部楼层 |阅读模式
例如一个矩形(Lwpolyline),现在的情况是: 这个矩形不平行与WCS的X,Y ,而是平行与当前UCS(已经plan显示了),用vla-GetBoundingBox返回的还是WCS中的边界的MinPoint和 MaxPoint.这显然不是我们想要得到的结果.
请教各位大虾,有没有什么办法获得正确的边界最大最下值的坐标?
 楼主| 发表于 2004-8-23 14:46:00 | 显示全部楼层
每人顶?沉了,,,,唉....
发表于 2004-8-23 14:54:00 | 显示全部楼层
Signature
RetVal = object.TranslateCoordinates(OriginalPoint, From, To, Disp[, OCSNormal])
Object
MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_utility_object.htm" target="_blank" >Utility
The object or objects this method applies to.
OriginalPoint
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the original coordinates to be translated. This parameter can be treated as a point or a displacement vector depending on the value of Disp.
From
AcCoordinateSystem enum; input-only
The coordinate system from which the point originates.
acWorld
acUCS
acOCS
acDisplayDCS
acPaperSpaceDCS
To
The coordinate system to which the point will be converted.
acWorld
acUCS
acOCS
acDisplayDCS
acPaperSpaceDCS
Disp
Integer; input-only
A displacement vector flag.
TRUE: OriginalPoint is treated as a displacement vector.
FALSE: OriginalPoint is treated as a point.
OCSNormal
Variant (three-element array of doubles); input-only;optional
The normal for the OCS.
RetVal
The translated 3D coordinate.
发表于 2004-8-23 21:04:00 | 显示全部楼层
将矩形变换到WCS,应用Getboundingbox方法,在变换回去。
 楼主| 发表于 2004-8-25 10:25:00 | 显示全部楼层
alin发表于2004-8-23 21:04:00将矩形变换到WCS,应用Getboundingbox方法,在变换回去。
想来想去可能只有这个办法了,但是如果当前UCS是一个任意的,没一个面平行于WCS,如何?
发表于 2004-8-25 15:17:00 | 显示全部楼层
Set a temporary Object UCS
GMT+8, 2025-9-30 04:04 , Processed in 0.158520 second(s), 26 queries , Gzip On.
