查看: 1614|回复: 1
回调函数可否含有ACAD的command?
发表于 2004-8-19 10:21:00 | 显示全部楼层 |阅读模式
在reactor的回调函数中可否含有ACAD的command。 我只知道在回调函数中: 1-需要避免用户的输入; 2-必须具有参数来接收reactor的参数。 我所要调用的command并不需要用户输入,输入参数我都已经设好了。
发表于 2004-8-19 10:31:00 | 显示全部楼层
  • Do not use any interactive functions in your reactor callback function (for example, do not use getPoint, entsel).
Attempting to execute interactive functions from within a reactor callback function can cause serious problems, as AutoCAD may still be processing a command at the time the event is triggered. Therefore, avoid the use of input-acquisition methods such as getPoint, entsel, and getkword, as well as selection set operations and the command function.
GMT+8, 2025-7-29 11:35 , Processed in 0.213261 second(s), 25 queries , Gzip On.
