查看: 2272|回复: 2
[求助]怎樣將圖層顯示反向選擇關閉其他圖層顯示?
发表于 2004-8-28 19:06:00 | 显示全部楼层 |阅读模式
小弟知道晓东工具箱里有这个lisp程序,这个程序真的很棒!但却需配合接口,能不能不用配合接口而能使用呢?以下是晓东的程序,可以更改吗? (defun #push_lay (lyr)
(if (member lyr #lyr_l)
(prompt "\n已经选取了改层,请继续...")
(setq #lyr_l (cons lyr #lyr_l))
(redraw e 3)
(defun c:slayres (/ e #lyr_l n)
(while (setq e (car (entsel "\n请选取要保留图层上的实体<退出>:")))
(xdrx_setenttodb e)
(#push_lay (xdrx_getentdxf 8))
(if #lyr_l
(xdrx_begin '("expert" 1
"cmdecho" 0
(command ".layer" "of" "*")
(foreach n #lyr_l
(command "on" n)
(command "")
(setvar "OSMODE" 4261)
(xdrx_end)
(defun c:slayoff (/ e #lyr_l n)
(while (setq e (car (entsel "\r请选取要关闭图层上的物件<退出>:")))
(xdrx_setenttodb e)
(if #lyr_l
"cmdecho" 0
(command ".layer")
(foreach n #lyr_l
(command "of" n)
(command "")
(setvar "OSMODE" 39)
(xdrx_end)
发表于 2004-8-29 00:18:00 | 显示全部楼层
;;;*图层隔离 c:tcgl
(defun c:tcgl (/ s1 la)
(WHILE (NOT (setq s1 (entsel "\n\t选择层物体: "))))
(setq la (DXF 8 (entget (CAR s1))))
(command "layer" "s" la "f" "*" "")
) (defun dxf (code elist) (cdr (assoc code elist)))
 楼主| 发表于 2004-8-29 00:45:00 | 显示全部楼层
出现错误: no function definition: DXF
GMT+8, 2025-4-29 16:42 , Processed in 0.172169 second(s), 23 queries , Gzip On.
