查看: 1241|回复: 3
求救
发表于 2004-9-1 11:34:00 | 显示全部楼层 |阅读模式
是不是用。NET2003装不了ARX2004啊,我一装它就说没有装。NET,可我已经装了啊,痛苦啊,上班急用啊,有知道的请说以下解决方法
发表于 2004-9-1 12:48:00 | 显示全部楼层
你下载最新的嚮导就可以 以下是最新嚮导说明: Version 3.2.0.0: * New feature list: - Now install on both .NET 2002 and 2003 (NOTE you must use VC7.0 still) - Dropped ARX Help button in favor of the Integrated Visual Studio Help (See DevNote #83661) - Dropped 'Code Finder' button in favor of the Dynamic Help from the Integrated Visual Studio Help (See DevNote #83661) - Code Gallery is now available (and synchronized with ADN) - LiveUpdate is not anymore automatic - acad.rx generation is turned off by default.
* Bugfix list: - ACE - Add Class wizards adding class to the wrong project - ARX Command Wizard not working on .NET 2003 - Member Variable Wizard not working on localized Visual Studio .NET releases - Eratic Unhandled Exception on Wizard launch - Eratic loose of Wizards configuration Version 3.0.0.0: * Shipping version
 楼主| 发表于 2004-9-1 14:15:00 | 显示全部楼层
唉,楼上知道在那可以下载吗?如有知道arx2005下载链接的也告诉我一下!还有vc7.1就不能用了吗,我是新手请指教
发表于 2004-9-1 17:34:00 | 显示全部楼层
下载是需要安装好自动下载的,
我不知道确切的下载地址,
arx2005下载链接你搜索论坛.
vc7.1不能用.
GMT+8, 2025-2-23 07:05 , Processed in 0.173370 second(s), 23 queries , Gzip On.
