查看: 2144|回复: 2
[求助]以下是什麼意思?
发表于 2004-9-2 15:55:00 | 显示全部楼层 |阅读模式
;;配套程序(x_draw ss key)
(defun x_draw (ss key / n e)
(if (= 'PICKSET (type ss))
(repeat (setq n (sslength ss))
(setq n (1- n)
e (ssname ss n))
(redraw e key)
) 以下是什么意思?
亮显时候调用 (x_draw ss 3) ,回显(x_draw ss 4)
发表于 2004-9-3 00:13:00 | 显示全部楼层
参考: (redraw [ename [mode]])
Arguments
ename
The name of the entity name to be redrawn.
mode
An integer value that controls the visibility and highlighting of the entity. The mode can be one of the following values:
1 Show entity
2 Hide entity (blank it out)
3 Highlight entity
4 Unhighlight entity
The use of entity highlighting (mode 3) must be balanced with entity unhighlighting (mode 4).
 楼主| 发表于 2004-9-3 07:51:00 | 显示全部楼层
哦!我懂了
GMT+8, 2025-4-29 16:39 , Processed in 0.168073 second(s), 23 queries , Gzip On.
