查看: 1916|回复: 2
如何將一實體的線型改變?
发表于 2004-9-3 16:33:00 | 显示全部楼层 |阅读模式
如何将一实体的线型改变?我的程式哪有问题?谢谢帮忙!!! .......
(command "line" x1 x3 "")
(setq x(entlast))
(command "change" x "properties" "ltype" "dashed" "")
发表于 2004-9-3 17:19:00 | 显示全部楼层
可能该线型还没加载
  1. (IF (NOT (TBLSEARCH "LTYPE" "DASHED"))
  2. (COMMAND "LINETYPE" "Load" "DASHED" "acadiso.lin" ""))
复制代码
发表于 2004-9-3 17:49:00 | 显示全部楼层
fend_2000发表于2004-9-3 16:33:00回复:(fend_2000)如何将一实体的线型改变?如何将一实体的线型改变?我的程式哪有问题?谢谢帮忙!!! ..............(command \"line\" x1 x3 \"\") (setq x(entlast)) (command
少了一个回车 (command "change" x "" "properties" "ltype" "dashed" "")
GMT+8, 2025-9-30 05:04 , Processed in 0.148090 second(s), 25 queries , Gzip On.
